Remote Brake fluid Reservoir - Whats required ?
  Clio 182
Looking to move the fluid res , whats required ? What size fittings go into the Master cylinder ? what hose should i use ?
Brigsy
  T.Turbo
I use a clio v6 remote reservoir on my Trophy. The bottle is an ATE one shared with bmw and angled plastic fittings that fit in the top of the master cylinder joined by rubber brake fluid resistant pipe. The ATE bottle is easily available and renault level sensor fits straight in, however if your using normal cable clutch you will need to block off the feed for the hydraulic clutch. Other option is to use a universal reservoir, shoudl be able to ick up the plastic push in fittings up ok.
Old one showing pipe run
New one fitted with nimbus heat shield
GasManLS7
  Clio 182
I use a clio v6 remote reservoir on my Trophy. The bottle is an ATE one shared with bmw and angled plastic fittings that fit in the top of the master cylinder joined by rubber brake fluid resistant pipe. The ATE bottle is easily available and renault level sensor fits straight in, however if your using normal cable clutch you will need to block off the feed for the hydraulic clutch. Other option is to use a universal reservoir, shoudl be able to ick up the plastic push in fittings up ok.View attachment 1608213Old one showing pipe runView attachment 1608214
New one fitted with nimbus heat shieldView attachment 1608216View attachment 1608216View attachment 1608212
Hi mate, did the fittings at the master cylinder end come with the ate bmw reservoir? Just wondering where i can get some
Brigsy
  T.Turbo
Hello mate. I used the fittings that came with the car..measure up what you need and from what i recall universal adaptors for the master to push fir are easy to find.
GasManLS7
  Clio 182
Something like that I'm guessing? Will measure up later. Can you remember what size hose was needed for the ATE reservoir? 9mm?
Brigsy
  T.Turbo
I have no idea now being honest as done it years ago. Was a common size so could have been 9mm, measure the tails to check.
