Fitting Rims
  Renault clio 172
I own a phase 1 clio 172 exclusive and I’m wanting to get a second set of wheels for the car in order to get the original rims refurbished. I was wondering if it is possible to fit 16 inch rims with the following tyre dimensions- 195/45/16 to my car without having to change anything baring in mind it’s on lower springs and spacers which the previous owner installed.
If anyone can tell me that would be amazing.
Thank you
Rob
Thank you
It’s not that simple, we’d need to know what wheels, different wheels have different offsets.
Fundamentally the size wheel/tyre will fit within the arch, but you’d need offset information to finalise
  Renault clio 172
I’ll be honest this is my first car so when it comes to talking about the technical specs like the offset I don’t really understand what your talking about but what I can tell you is that I have 16mm spacers in the front and then 20mm spacers in the rear and the rims I’m looking at buying are genuine Renault rims from the 182 trophy so I don’t really know what the dementor this would be.
Thank you for your help it’s much appreciated even though I can’t give you the information needed.
Kind regards
Rob
Kind regards
182 trophy wheels
As in these?
Onto a mk2 ph1, yes they will definitely fit.
OssPoop
If you take the spacers off you'll have no issues at all, except for needing shorter wheel bolts maybe. And then preferring the car on the trophy Turini's and never going back 😂👍.
  Renault clio 172
Ok I’ll have to look into some wheel bolts and definitely I will probably prefer the Turini wheels but might go back as they are the rims for the exclusive that are on the car at the moment.
Thanks for the help everyone
