172 cup, what I wanted to do 20 years ago
clio_cup
Car  172 Cup
20 years, or near enough I bought my first Clio sport, a silver phase 1, W744WTR. I had this for 2 years and loved every minute of it. The poor thing put up with all the abuse I threw at it and never gave me any grief. I sold it when I needed a lot of money spending on it, and have always missed it. After a trip to spa this year with some friends I got the itch again. For the last 10 years I’ve been getting my business up and running and working well and now am in a position to do all the things to a Clio i wanted to 20 years ago when I just didn’t have the money to even run the car.
My main aim was to buy a car and not have to borrow any money, everything I do to the car it all paid for, no credit. When I was in my 20’s I managed to get into quite a bit of debt through loans and credit cards which took me 5 or so years to get cleared and I hated it. once back from Spa I started looking for a car, after looking at a few rough examples I found my current car on FB marketplace 40 minutes from me.
I wanted a car that was good enough but not perfect so I felt like I was ruining a good clean example. I’ve got a hilux for work and a disco 4 for family duties so this is just a fun thing to play with. Car had done 105k miles, been off the road for 2 years, and needed a mechanical refresh. The body was clean with not signs of any rust just the odd scape and one dent on the bonnet from someone shutting it like a savage. Paid £1650 and was on my was on the way home. I’m by no means a mechanic but I’m not bad so can do most bits with the exception of bits that are easier with a ramp. I’ve got a very good friend who owns a garage and he does those bits for me.
Starting off was a full service, all the fluids, new brakes including PBS track pads etc…. While doing the brakes I noticed the lines were look f**ked so replace those with a braided set replacing all f the rubber lines and did the full rear lines from the two soft lines back. Also while servicing the engine one of the coolant lines fell apart in my hand so a set of MTC hoses to replace those. The engine and dogbone mount were f**ked so badly the engine was rocking when you revved the car. Both replace with power flex bits. The car also had a misfire, I changed the coil pack and new ht leads but no luck so a new set of injectors and it was all sorted. The cambelt was 8 years old so off to my mates to have that done plus get it MOT’d. Car came back with 2 advisories, the exhaust was pretty much falling off and the tyres were all down to wear blocks. On the drive back from the garage I hit a bump and the exhaust snapped at the back box so onto the forum. Managed to find someone selling a PMS cat back exhaust so bought and fitted that. Next the tyres, the turinis were in a bad way. Most of the paint had come off the wheel so after looking at the wheel refurb and a set of tyres I ended up buying a set of Oz Superleggeras with ps3 tyres for less than the cost of the wheel refurb. As I want to do track days in the car made sense to go down to a 15” wheel for tyre choices. The car also had a nasty air filter bodged into the air intake elbow. i replaced it with the advocult kit with battery cover to tidy everything up.
Next was polishing the headlights, looked like frosted glass when I started. Bought a headlight restoration kit after a recommendation on here, not perfect but 100% better now. I’ll probably change the lights when I get a minute but it’s very low on the list. Fitted brass bushes and a new white bush to the gearbox to remove the sloppy gear change along with a ZPO gear knob. Raised the gear stick to an height that’s comfortable for me. I’d like an PMS shifter but don’t think I could deal with the associated racket that comes with it. Also had a PDR guy come and get the hand print dent out of the bonnet as it bothered me. Cost £300 but was well worth it. Next on my list was coilovers, after reading pages of stuff on here I settled for BC Ds as a starting point with a 7kg front and 8kg rear. Thought while the coilovers were being done might as well get a PMS anti roll bar and fit powerflex bushes to the rear beam. Handling is transformed on the car, drives like it’s on rails. Wish I had gone a little harder on the front but I may change that, or buy some ast 5100’s. Again low down the list now. With all these bits done in early September i did my first track day with the car. Over the course of the day managed just over 100 laps and brand hatch with out any problems. Had a blast.
Now to the current bits. This weekend I fitted some hub spaces on the rear with camber shims to fill the arches a little better got given these so seemed rude not to. Have also just sent my Quaife up to mark to get put into a gearbox. All being well, that will be fitted in the next week weeks along with a ttv flywheel and a new clutch. Need to order some 10mm spacers for the front along with studs and wheel nuts are pi**ing me off. I’ve bought a new set of 2118’s which will become my main wheels and the superleggeras will become track wheels. Should picking those up within the couple of weeks. I’m also waiting on my mate to get some bits done to his car so I can pinch his front hubs. Will get these sent up to Bridgecraft engineering to get the machining work done then get the roll centre kit fitted and get the alignment done again. I think that’s me up to date at the moment. Once these bits are on I’ll book another track day hopefully not to far away. Have got a baby due this week so that might slow progress a little.
The car has become a bit of a release for me. I’m a tree surgeon by trade and I’ve spent so long working 6-7 days a week and I now in a position where I don’t have to work weekends so I can do some bits on the car. I couldn’t do it every day but I enjoy working on it, even when it goes wrong. My 3 year old son also loves “helping” work on the car. Means everything takes a little longer but he loves it.
While I’m off work helping the wife after the birth of our second child I took the chance to go and pick these up from another member. In my opinion the best looking wheels for a Clio 1*2. Hopefully get the tyres mounted over the next week and with the spacers and studs.
Wheels are et43 with 205 tyres and will have 10mm spacers. Does anyone know of any rubbing issues with that size? Will probably look to get a set of AR1’s for the superleggeras and these will become my track day wheels. Also picked up a PMS shifter from the same member. Hopefully fitting that this weekend and then begins complaining about the rattling.
I run those wheels on 195's but without spacers, you shouldn't have any problems with rubbing.
Little update from the last week. PMS shifter fitted, followed the advice on here. Fitted the new bearing to the turret, packed the linkage boot with heavy bearing grease and fitted the rod with lead shot. Bearing easy to do if it’s not in the car, and lead shot for anyone looking for it search diving ballast. Same thing. 2kg was £20 delivered. Probably get away with 1kg. Getting the linkage set up correct was a pain in the arse. Also struggled to get reverse engaged. Two people make doing the linkage a lot easier, one in the car and the other one making the adjustments. Speeds the process up no end. Found it was struggling to get into reverse because the linkage was hitting the dog bone nut. Flipped the bolt around and that cured the issue. Next on the list was pms studs, simple job which I did while fighting with the linkage so the thread lock had a chance to set. Next was the 10mm front spacers and the speedlines. I’m sure it’s up for debate but I don’t think there’s a better looking wheel for the Clio.
Also fitted a set of pedal covers that a guy on the Facebook page makes. They’re a little wider than standard and just covered in black grip tape. Learning to heel and toe, I’m rubbish at it but I’m hoping to get better over what will probably be a long period.
Hopefully next on the list will be gearbox with lsd when it comes back from Mark, new clutch and lightened flywheel. After clutch suggestions from people? After looking at all the options for a bit more power I think I’ll fit the low boost ED kit. Cars not a daily. Also got the rest of the powerflex bushes to do. Want to get a smaller steering wheel and get that fitted. That’ll probably be it until the new year when I’m hoping to get the turbo kit done. Would also like to get some track time sorted but with a 2 week old baby it’s not going to be easy.
Have you taken the car for a drive since fitting the PMS shifter and the alterations? Any rattling?
If heard of the turret bearing change method. Is this the PTFE lined unit?
We're do you get these from?
So far not a single noise from shifter. Don’t know which of the three bits make the difference but I thought I’d do all of it before fitting.
Bearing came from Merlin motorsport search
NMB Spherical Bearing ABT12,
Just search diving weight for the lead shot, think that came from eBay, £20 for 2kg.
And the bearing grease I had at home anyway and just reused the existing boot.
Beautiful. Thanks for the breakdown!
Looks like the bearing will need to come from the UK. Can't find anything local with similar specs.
W744WTR! i had a theory a while back that these were some of the first vehicles produced for the UK.
You see a lot of W7**WTR in press pictures etc.
Mine is W748WTR - so probably came over in the same batch!
Love the car though, i was so torn between 2118s and TD1.2s. Went for the latter in the end purely on weight.
W744WTR was a press car before I owned it. When I got the car in 2005-2006 it was already on 4-5 owners. If you stick the reg into google it was the long term test car for EVO magazine.
Amazing post for me to stumble onto..
I bought my first Clio (182) last month, and it's a very similar list of jobs I am going to be doing soon.
Sounds like you are enjoying the car thoroughly :cool:
Lack of updates from me. Apart from fitting an OMP steering wheel nothing else has happened to the car, just been picking bits up for the work to start in January.
On the build list for Jan is a rebuilt gearbox with a Quaife, ttv flywheel, sachs paddle clutch, arb bushes, steering rack bushes, pms down pipe and decat, Advocult power steering line, oil cooler and ED turbo kit. Has been an expensive couple of months but though I’d get the whole lot done at the same time. Hoping to get a shake down day at brands hatch in Feb then a trip to Spa in March.
After a few weeks away the cars back. Mate who does the work for me is a busy man so it’s get done around his better paying jobs.
While it’s was with him he fitted,
ED low boost turbo kit
Mocal oil cooler
Evol engine and gearbox mount
NorthLoop rebuilt box with Quaife diff
Lightened flywheel
Sachs paddle clutch
Powerflex steering rack bushes
Powerflex anti roll bar bushes
Refurbed cup lower arms with Powerflex bushes and lemforder ball joints
New track rod ends
PMS downpipe and decat
I think that’s everything. Has been quite the drain on my wallet. Need to get some miles on the car now before it goes to engine dynamics in a couple of weeks for mapping. Needs to go back to the garage at some point to notch the subframe to stop the downpipe hitting it. He tried everything but there just no space, equally if it clearances itself then that’s fine. Will be back with him before the end of March for a nut and bolt check before a track day at Spa. Have also got a set of Wilwoods to get fitted to the car before we go.
Excuse the rubbish picture forgot to get one in the nice lights in the garage. Ended up taking it at home in the dark and the rain.
Made the early morning trip 80 miles to engine dynamics to get the car mapped.
A friend follow me up in his cup to keep me company, that an I think he just wanted to go for a drive. It’s a pretty dull drive from mid Sussex. A22, M25, then the A12 and we’re there. Got there for 8.15 little bit of chatting then left Andy to it while we went and got a coffee. Can back and sat in the waiting room while he finished off. This is the first time I’ve ever had a car mapped in the 50+ cars I’ve owned. Something quite unnerving hearing your car revved to the moon but all was fine.
While we were sat in the waiting room we sifted through the pile of old performance French car mags. Managed to find the one which my mate managed to get his 205 feathered in that he built in 2013-14. Ended up with a final number of 237hp. Can’t remember the torque but if anyone wants to see the graph I’ll stick it on here. All done and the car working well was just the uneventful drive back to Sussex but able to use the boost now. I’m sure it’s not to everyone taste but it makes me smile.
Noticed the Advocult power steering line is weeping a little so need to get that sorted, the exhaust is knocking on the subframe which is driving me mad so going to notice the subframe, then the Wilwoods to fit and I think I’m ready for Spa in March.
Totally agree about having the car tuned and it being rev'ed to within an inch of it's life. Full grimace mode from me 🤣
A friend follow me up in his cup to keep me company, that an I think he just wanted to go for a drive. It’s a pretty dull drive from mid Sussex. A22, M25, then the A12 and we’re there. Got there for 8.15 little bit of chatting then left Andy to it while we went and got a coffee. Can back and sat in the waiting room while he finished off. This is the first time I’ve ever had a car mapped in the 50+ cars I’ve owned. Something quite unnerving hearing your car revved to the moon but all was fine. View attachment 1778073
Nice work!
Should move nicely with 237!
Where exactly are you having the leak from the Advocult power steering line?
I've seen people have it around the sensor area in the past.
Looks like the leak is coming from the banjo bolt where the line fits to the pump. Going to clean it off and give it 1/4 turn and see if that cures it.
I had the same thing, nipped it up and it stopped but I think it's still weeping a tiny bit. I'm going to remove the fitting again and replace the supplied copper crush washer with a dowty washer
Have just been under the car in the rain trying to sort this. Tried to nip
It up but it’s tight, weeps a little still. I’ve come to the same conclusion as you, going to remove the copper washer and replace with a dowty washer. By chance do you know if it’s the same size as the sump plug washers. I’ve got loads of those.
Hope that works for you. I just had to go and read up on dowty washers, what a brilliant idea. As pressure increases, the seal gets better. Sounds like it should sort the problem.
I love when someone who really knows a subject sees a simple solution to a problem, and invents something like this.
I don't off the top of my head, I've got a box of assorted dowtys in the garage, worth having one for things like this
Saturdays are normally reserved for me looking after the three year old and 4 month old so my wife can get some horse related stuff done. But I’m running out of time before we go to spa so both boys had to “help” me get bits done on the car.
First thing for this morning was fitting a turbo blanket, not sure if it’s the right thing to do but trying to manage heat as best I can. There is little to no room to get the turbo blanket in place then the much harder job of getting the springs in place to hold it on. After about an hour of swearing, crushing fingers, and cutting my hands to pieces it was fitted. Yet to drive it to see if it actually makes any difference. Next on the list was sorting the leak on the Advocult power steering line. After trying to squash my arm through what left of my arch liner I decided removing the front bumper would be the easier option. With the bumper removed access to the high pressure line was better but still not perfect. I removed the line from the pump and replaced the copper washers on the banjo bolt with dowty washers. These seemed to be enough to stop the weep from the banjo bolt so a success. I was getting ready to rip the PAS out of the car all together. Final thing for the day was starting to strip the rear seats out ready for when I can find a cage to fit. All the bolt are out now, just need to removed the seatbelts tomorrow, then free up some money for a cage at some point. Im still on the look out for an MSV /caged laser bolt in cage, ideally not for the £1000 they want for a new one. With a good couple of bits off my list today I’ve only really got to get the car cleaned and I’m good to go. Has to go back to my mate to get the subframe notched as the knocking is driving me mad. He’s also going to fit the Wilwoods for me while he’s got it. I’m perfectly capable of doing it at home it’s just a lot easier for me if he does it. Lazy I know, but the two small children make every job two or three times longer than it should be.
Little update from me. Car went back to my mate today for a quick nut and bolt check and to notch the subframe before spa. Ever since the turbo kit was fitted the exhaust has rattled on the subframe and drove me mad. Thankfully he worked his magic and the rattle is gone, just get the vibrations from everything else now with the solid mounts. Also got him to fit the Jamsport Wilwood kit that I got from another member. Yes I could do it at home but I’m being lazy and got him to do it while it was on a ramp. The brakes are probably massive over kill but was amazed how much speed you can scrub very very quickly now. Also removed the rear seat if I haven’t mentioned that already for when I eventually get a cage.
I’ve also been in a mad rush to try and find a buckets seat. What I’ve discovered is the being 6’ 4”, 88kg and 40cm wide hips I’m not the same shape as whoever they make buckets seats for. Tried to get some Corbeau pro sports but they’re 1-2 week wait and we go next Saturday. Have decided just to leave the cup seat in for the minute and will carry on my search when I get home. If anyone has any suggestions of a seat with a 40cm wide base please feel free to drop them below.
I had a bimarco futura in my MR2 years ago, was a pretty roomy seat, ideal for bigger guys. I think the cobra 3 is the current version
This trip is what kicked off the purchase of the Clio for me 12 months ago, the want to have a fun car again. Cars come along way in less than a year. It was the first test for the Clio since the turbo kit was fitted, the drive to spa, a day and a half of driving, and the drive home again.
When planning the work on the car I had hoped we had left enough time to get a “test” day at brands before the big trip to spa. As it all worked out had no time for a test day in the UK so jumped in at the deep end and loaded the car off and headed to Spa. Nervous was an understatement, having only put a couple of hours in the car since fitting the turbo kit I was really unsure how this was going to go. Left home just before 6am on the Saturday, met up with @cjgower and a few other on route to the train. Then was the 4 hour drive France side down to spa. Averaged 75 all the way down, was all very uneventful thankfully. We stayed at a hotel just outside the main town and only 800 metres from the track entrance. Had ample parking for trailers so I’d highly recommend it to anyone towing down there. Was around £400 for 3 nights with breakfast.
Up at 6.30 the next day to get down to the track and get set up. The other two people I was staying with trailered down so a few bits to get set up.
The yellow clio and radical were booked for both days. I stupidly had only booked for one. Having a garage made a big difference, driving straight onto the pit lane saved a lot of time over the day. Heard from some other people that the Sunday had been over sold by quite a lot. Meant the circuit was always very busy and there was quite a lot of queueing to get onto track. Even with all the queues I was still managing a 15-20 minute every hour then leaving it to cool for at least 20 minutes. Even on hot laps engine coolant never got much above half way on the gauge so very happy with that. Was a big concern that it was going to spend most of its time over heating. Next on the list of bits to get done is for an oil temp & pressure gauge so I can keep an eye on what that’s doing.
Only had one minor issue all day. Half way through the afternoon session one of the exhaust bungs came loose and now lives somewhere at spa circuit.
No real issues caused. Caught it early enough so nothing had a chance to melt. Fortunately after asking everyone I could find to ask there was a very helpful Dutch team with a bmw support lorry. Turns out a bmw diff drain is very similar to an exhaust bung so with that wound in we could carry on for the rest of the day.
With the first day going so well I was itching to try and get a drive on the second day. After asking around in the pits seemed a lot of people had the same idea so nothing worked out. In the end the yellow Clio kept loosing its exhaust studs so my friend gave me his number to drive the afternoon session. The track was much quieter today so that lent itself to a lot more track time for me and the can again ran perfectly for the rest of the day. Only thing that did become apparent by the end of the day was the 6 year old multiple day ar1’s were very much on their last legs. As the day went on they seemed to loose their grip much earlier into each session I did.
Packed up around 5, calling it quits early. Had a good day and didn’t want to push my luck. Had two trailers to get loaded plus all the other bits we had brought down. The bonus to having a garage is you can leave it all there so you’re ready to go on the second day.
Early dinner then bed. Had the train booked for 10.40 am. With both my friends towing they wanted to leave at 5am to allow the extra time to get back to Calais. I also left at 5 but managed to get to the tunnel by 8.45 and with luck on my side got the 9.15 train and back home by 10.30. All in a very fun trip and can’t wait to do it again next year.
Little update. Friday after work I manage to get the drivers seat and passenger seats stripped out of the car. I wasn’t the first person to be under there as something terrible has happened to the wiring. Ends had badly crimped and as I rocked the seat back everything pulled out of the connectors so need to figure out what to do there. May need to find someone local with a clip tool to get them turned off permanently. If you do have a clip tool near Sussex can you shoot me a PM. Bought a cage from Rob Cheesborough, I know a few people have got cages from him. I wanted one that was 100% bolt in so when I find out the cars a rot box or I smash it up I can unbolt everything and swap it with little fuss. The cage I bought was a cancelled order. Only problem was it was yellow. Had hoped I could live with it being yellow but when it turned up it then went straight to the powder coaters to be redone satin black. Picked the cage back up this week so called a mate this morning to give me a hand lifting it in. With it having the x in the main hoop and a harness bar it adds quite a bit of weight. Going in with blind confidence that others have fitted these single handedly I thought we’ll breeze this. How wrong I was. Even having looked at all the pictures of then being fitted and asking Rob the techniques still got it wrong. Was a lot of trial and error getting it in until we realised we were being stupid and after that it was very straight forward. Next it’s the two bits over the rear struts we set to mounting the other four points. Was a bit of a fight to get one bolt in but all went well.
After this I got the caged snugged up was onto the Jon foz frames. These all bolted in with very little fuss. Just waiting on the seats to be delivered now.
I've seen a couple of those cages now and they absolutely terrify me.. main hoop mounted with a single bolt each side in single shear, and the rear diagonal bars mounted to the rear shocks .
If you're happy that it's just a 'faux cage' than that's cool, but I wouldn't be expecting it to save my life in a roll over
Bucket seat fitting this weekend. A couple of weeks ago it was a hot afternoon so decided to leave work early and drive to the Corbeau factory. Wanted to place an order on some pro sports but thought I should probably sit in them first before buying. Just as well I did, didn’t like the fit of the seat at all, and ended up buying a sprint x. Fit me better and just felt a lot nicer to sit in. Got the Jon fox frames fitting first which was a piece of cake, really easy and very straight forward. Problems started with the seats and me thinking everything would simply just bolt in. To get the seats and back to where I found comfortable meant I had to drill four new holes, none of that was very hard just quite time consuming to mark, measure, check, drill test fit and so on. With my kids helping this took a lot longer than planned but they were in. Then my planes for mounting the harnesses quickly failed. The seat was mounted back too far to use the original seat belt mount and the brackets I bought to bolt into place didn’t work as there wasn’t the room for them. Fortunately a mate had some of the spreader plates and after a bit more drilling and checking I wasn’t going through the fuel lines or brake lines the eyes were in and the harnesses fitted. Not the quick job I had planned but all worked out in the end.
Small little update. I’ve had the Clio just over one year now as it was MOT time. Dropped the car off with my mate to get the MOT done, while it was at the garage had I had him fit the Pro am geo correction kit. As with most bits on this car I can fit these bits at home but with two small kids and running my own business I have little to no spare time at the moment. I had intended to get a bridge craft kit from Allan. I had picked up another set of hubs ready to send up to him but after sending an email I didn’t hear back from him. I’m sure he’s a busy man and didn’t want to chase him so ended up buying the kit from Pro Am. The kits very nicely made and I sure for what I use the car for it’ll be perfect for me. I’ve not had a huge amount of time in the car with the kit fitted, but wow has it made a difference. Suspension feels less crashy, and the steering seems more direct. Is highly recommend anyone with coilovers getting one of the kits. Planning on getting another brand hatch day booked for early June, and then planning on doing the day trip to simply french at the end of June.
