Rojer's 200T
Rojer
Picked up today from @charltjr It's actually tidier in person than I expected. The colour is beautiful in the sun, in photos it tends to look a bit washed out, but in person it really pops. So far I'm really impressed with it. It's everything I hoped my Fiesta ST was going to be. The Clio has a much better driving position, its very comfortable and the auto box is smooth and quick. Took it for a quick blast down some local lanes and its awesome. Steering is great, tons of grip, brakes are good, even the interior is creak and rattle free. I really don't understand the hate these cars got. I don't mind the paddles, but they desperatley need to be extended. If anyone has some good options that are not the Life110 ones, let me know!
Couple of jobs on the list. It could do with alignment and probably brake fluid as John did everything else. The handbrake is rubbish so that needs adjusting. I need to remove the other stupid diffuser stick on extender thing and the horrible carbon wrap on the front badge and fit the aux belt kit. Other than than it would be good to smoke test it and upgrade the screen if possible to a later one with android auto. If anyone could point me in the right direction, that would be great.
Rojer
Had an hour after work so wanted to make a start on a few jobs. First thing to go was the stupid diffuser extenders. Looks much better without them!
Next on the list was to investigate the poor handbrake. Thanks to a lovely video from @Adey. I had access in no time. Unfortunetly it wasn't just a case of tighening it up. Either the caliper has seized or the cable has snapped. Couldn't get it to move in or out. Further investigation required.
After melting in the heat and putting it back together, I decided to plug in the code reader and have a poke around. No faults in the engine or gearbox and a few old/random faults in other modules. I wanted to have a look at the AC and it came back with the following code. If I cleared it, it just came back.
Went into the engine bay and 0 gas in the AC system so no doubt it has a leak and potenitally the control panel needs replacing. Next job was to take off the horrible carbon wrap. I knew it was there for a reason and sure enough the badge is broken. Can you buy a new badge seperatly?
Finally I did a few smaller jobs. Removed the boost solenoid and gave it a rinse with brake cleaner. Topped up the oil and had a general look around. It has the old style brake reservoir cap, so I will order the updated one. This pipe is going to need replacing and looks like its the best part of £300 from Renault :( It also has an interesting jublie clip with a tap style adjuster lol so I doubt that's factory.
Had a look at the aux belt and that looks like it needs to be done sooner rather than later, also not sure if the downpipe has been messed with as that doesn't look like a factory bolt/one is missing.
Overall nothing too serious to sort out and things like this are to be expected on a cheap car. I will get these bits sorted and go from there.
Rojer
Done some digging through the parts diagrams and ordered a couple of bits.
Looks like there is an o ring on the cold side boost pipe so I have ordered that as a precaution. Number 37 part number for ref 7701071316. Also ordered a new badge 628909470R.
Looks like I'm missing a heatshield on the downpipe (208501KC0A) and that missing bolt just holds the heatshield on so no real dramas. That odd looking bolt should be a nut though so I'm guessing someone changed the downpipe at some point and snapped the stud and just used a bolt instead. I will need to take a proper look at that.
Adey.
I think from memory I just swapped over the seal from my old pipe, that said, it doesn't fit very well and leaked on mine when smoke tested. I also haven't tried it with a new seal so it could just need that. Instead I shimmed it with a little coke can behind to improve the squeeze. Now you've reminded me ill order a new seal :D
  2014 Clio 200t edc
Nice pick up. Genuinely one of the best cars I’ve owned and would have another in a heart beat! I fitted one of the metal hot side pipes as well, purely because it’s not a case of if it fails and more when it fails. I’m sure I used the original seal with mine and it was ok but for the cost of a new one it’s worth changing.
I also fitted a 220 intake (numbers 10 and 11) that I managed to get second hand. Felt like it made a difference, and in fact there was a company or someone who was selling them new.
Rojer
Overnight parts from Airtec, after worrying about a seal. It looks like they include their own now! I hope this fits the standard intercooler, probably should have checked that first.
I also managed to get an account and paid an hour for access to the Renault portal https://newdialogys.renault.com/ It's quite good, it has all the parts diagrams, repair instructions, wiring diagrams etc, but it also gives you service history and it looks like you can add your own records. Good to see the car went to the main dealer for the first 4 years at least so I have a bit more history.
Rojer
Some serious words need to be had with the previous owners of this vehicle! Lets start with some good news. It was my first time working on a MK4 so decided to get the bumper off to give me a bit more access to the cold side pipes.
That will be the reason why I have no AC gas then.
After a bit of a faff, managed to get the new pipes installed. The fitment isn't the best. I did clearance the slam panel, but it doesn't fit too well with the bumper on and I cant get the last bolt in. I will have to have a bit more of a play around with it. During the swap, I went around changing some of the non standard jubliee clips for standard ones.
The air duct behind the front bumper is also broken so it must have rolled into something and that's how the badge broke and bonnet got a dent.
Managed to replace the aux belt, didn't bother with the tensior as it felt and sounded fine, but at least I have a spare if needs be. Whilst I was in there, I noticed the postive battery terminal was very loose. Also the way it was orientated, it was stretching the power cables and exposing the wire. If that touched the intake heatshield or something else metal, it could have been a very bad day. Now in the correct orientation and tight.
Onto some of the bad bits. I dropped my 10mm so had to remove the undertray to retrieve it. The front wheel bolts were finger tight, the front pads and discs are nearly non existent, it's leaking cv grease all over the drivers side, various wrong/broken/missing clips, I think it has a slight exhaust blow and the engine/underneath is generally very dirty and grimey.
Anyways, back on its wheels and torqued them up. Took it for a drive and it definetly feels a bit keener. The country lanes around me are fairly bumpy and you can tell the shocks are past their best so I will probably end up replacing the lot at some point.
I guess I better go and order some more parts!
Rojer
Probably this :
Thought as much. The problem is with the metal elbow on the throttle body they provide. If I lengthen the amount of adjustment, that should get it to fit nicely so I will sort on the next round of work.
To make it clear, I was only joking about the previous owners. On a cheap car all these sorts of things are expected and I'm not complaining or blaming anyone for anything.
Anyway, front brakes ordered along with a CV boot kit.
