Welp AC pipe
Tin.tin
  Clio 182
Hi gents
Does anyone know where I can get high pressure AC pipe? Or part number?
Believe it goes from bulkhead to condenser.
Currently at the garage having condenser done but turns out this pipe is broken .
Garage struggling to source one.
Any help would be massively appreciated
Martin_172
a specialist breakers like Renomotive will have loads of them id have thought, i got a pair from a scrappy last week for a non RS which is slightly different where it meets the compressor
Tin.tin
  Clio 182
Thanks man luckily found one on Ebay had it fitted along with new condenser & gas. No leaks however ac still not working. Read somewhere, car's meant to make a clicking sound when you press Ac button but mine doesn't do that when pressed.
Mechanic plugged it in apparently got a code related to compressor wiring, have you come across anything like this?
JimF
  Clio 172
I may have one if you're struggling. Well I definitely have one, its whether I broke it removing it or not.
Tin.tin
  Clio 182
Managed to get one off eBay luckily thanks anyhow. May be worth a gazzilion quid soon I’d keep hold of it lol fingers crossed not broken.
