Sim Rigs - Let’s see yours
Ah didn’t realise you needed an adapter. Still might be something to look into.
Moza not compatible with ps5 unless you don't mind using an adaptor. £520 is a cracking price for the RS50.
As for a rig, if you can leave it setup I'd go for an extrusion type one (SIM lab, GT omega prime etc). They are quite industrial/ ugly. If you need something more aesthetically pleasing with the possibility of sliding it away behind sofa or in a cupboard, a lot of people like the Playseat Trophy.
Hang on with the RS50 you still need to stump up another £350 for the pedals? Do they not sell a bundle?
They don’t, but even so with the vouchers it comes to £520 with the basic pedal set, which is a load cell brake
I get the Logitech set coming in at £680? You must have some cracking vouchers!
That's ps/pc base, stock pedals, Xbox wheel hub and track rim as round is out of stock.
Two codes, one is HOLLOW and then sign up for the newsletter and they send you a 15% voucher code. Can use both.
It's £530, or do it in two transactions (rim and pedals separate) and strangely it's £520, just need two 15% codes.
3D printed clips for the NLR GT Track frame.
Two sizes for the difference leg sections - clip on perfectly. No more shitty dangling wires or cable-ties attempting to keep it all neat.
Went for the knock-off 8Nm boost kit over the 5Nm default Fanatec offering. Half the price of the official item, but it works well. Glad I bought it.
I did the same as you but got it from aliexpress. Looks exactly the same and is cheaper, so long as you don't mind waiting longer for delivery. I agree though, it works well and no issues.
That's OK then. Just thought you'd thrown in the towel completely!
Its finding the time. Once I get into a decent routine I'll try to get at least an hour a day in at some point. Forza will be the catalyst I expect after holiday.
Think I’m late to the party but this is my set up!
Triple 34” MSI ultra wide, Ali profile rig, simagic eco system- P500 pedals which are being upgraded to sprints soon, alpha mini wheel base and GT Neo wheel
i5
4060
1tb storage
Finished doing Nords 24 today in the Porsche cup on iRacing, normally an LMP3 merchant in officials and competing in leagues :)
Upgraded my single 49" UW to triple 32" monitors last week. Bought them off a dude local to my work who was looking for a quick sale.
We done the Nurburgring 24 at the weekend also and managed to bag the win in the TCR (Split 3 on the main timeslot).
Thinking of adjusting my GT Track pedal plate to be at an angle - see how that fares. Do many others just leave their pedal bases horizontal, or on an incline?
I tend to have the seat, wheel and pedals in a more traditional car position, rather than an F1 style. I've seen some setups where the recline has been set so far back, it's like being a ball turret gunner on a B-17.
Built my own using ffbeast and a hoverboard motor and part CNC’d carbon fibre sheet and 3D printing for the actual wheel itself.
Pedals from from a design I liked the look of, CNC’d sheet steel (powder coated) and load cell for the brake.
just finished up the final design for the wheel base as the current version is bolted to 2020 extension which is clamped to my desk via 2 massive bessey clamps, will be glad to be rid of those!
A home made wheel?! I think we need pictures of this.
Don't disassemble parts and leave then on a table for the cat to knock on the floor..... :rolleyes:
So, Fanatec wouldn't offer a replacement outer cover when I contacted them. What I found to be a bit strange is that it's simply connected with four bolts - the locator hole for one of the bolts being at the upper centre of the pic above.
They have however, offered an RMA service - to which I cannot confirm if they will replace the entire motor base section, or simply replace the rear cover themselves. I've got the serial number of the outgoing base and I know there's a small mark on part on the metal body - so will compare those details against the 'new' one when it arrives.
Turns out I got a brand new CSL DD wheel base as the serial number is completely different to the unit I'd registered previously and sent back to them.
To say that they replaced it FOC when the warranty expired back in March of last year, is pretty impressive. More so, it's only been 6 days since I dropped the old unit off for posting.
I'm impressed. :)
I'm impressed. :)
Customer service only @mace¬ could have dreamed of 😝
Currently I need to re-print the base since it’s currently held down with 1 meter clamps, I have made the changes to the model from this prototype, but need to print it.
the belt you see is the encoder and it the tensioner/encoder mount I borrowed the design from somebody else (the roller isn’t fitted in one of the pictures)
There’s 50,000 pulses per revolution of the wheel.
It’s absolutely rock solid, hundreds of hours and barring a few screws here and there coming loose because I didn’t loctite them (they are now!) it’s as solid as day 1, there’s zero play on anything.
I bought a quick release mount from AliExpress but currently I only have this wheel.
I have a fan pointing at the rear of the motor (Noctua), currently it’s just resting there off angle and the motor runs completely cool with the fan, I’ve seen people over complicate their designs with fancy shrouds for the fan.
I also knocked up a piece of software for a pi pico that uses an 8x8 thermal module so that I could monitor the temperatures when I was developing this.
