First Car Project - Clio 172 PH1
Well that went well, not.
The timing tool I bought doesn’t fit the engine. The cam locking tool doesn’t fit the cams. So I’m going order a Renault one of them as with that and the rest of the US Pro kit it’s ok. I can’t imagine the crank pin and locking bar to be different as it’s apparently for a F4R engine. Too add to that, no one had a 14mm Alan key for the dephaser.
However, it’s all striped now so it’s just a few bits I need to fix the car. The crank pulley rubber is all cracked and horrible so that needs a change and it seems like the water pump is just a generic knockoff one so I’m glad that’s being changed.
Apart from that, I haven’t found it that bad stripping the belt down at all. It doesn’t seem as hard as everyone says, saying that, I haven’t exactly done the hard bit of timing the engine.
You would definitely be better off with oem renault tooling. The setting bar fits better than aftermarket.
Follow workshop manual to refit, and you cant really go wrong if its all torqued correctly. Only seems to go wrong with people cutting corners, gunning up the crank or cam fasteners etc.
Could that immobiliser light that’s constantly on be caused by some dodgy connections within the door wiring where it goes into the lock?
The alarm still works as I found out today at half 8 this morning when it woke everyone in the street up.
I remember the plug was a bit crusty inside but must still have some connection as the internal central locking works.
First mod for the Clio is the original Cassette player, mainly so I can use the 6 disc changer. I can’t decide whether to keep this or put the very 2000s Sony back in, prefer how the Sony looks but I like the changer.
Can’t seem to get it to line up properly, it’s like it’s too big but it just needs a bit more movement I think. There’s also a lot of sticky stuff now over the centre silver trim from what’s left of the material that covers the wires. It’s a pain to get off
Also, the key is now fixed, guy thought it wouldn’t work as the LED wasn’t illuminating but it works the central locking. Seems to be missing the LED on the PCB.
Good luck!!
I managed to get mine lined up first time at the weekend, felt very smug.
Engine was on a stand though, and had no VVT to contend with either! 😅
maybe save that review until Monday ;).
I partially agree though, just because things are frequently done badly doesn't necessarily mean its hard, perhaps just means too many people try and wing it (unsuccessfully).
it may open a can of worms. If you think it's a one day job it's probably two. Find a cracked bracket and suddenly it's seven.
And I don't say that to scare you, it might all be fine, from experience on these cars it rarely goes to plan!
Currently day five of the estimated seven, good to see some things are going to plan though. The fob was an relatively easy fix!
Welcome to Clio ownership, I would suggest buying a multimeter ASAP - you will more than likely get your moneys worth...
Could have tested it using diode mode 👀
I’m mainly days 5 due to a huge lack of tools I didn’t even have the 14mm Alan key for the dephaser and the crank pulley was absolutely ruined so I’ve had to fork out for one of them too.
The fob I’m so happy about, I really couldn’t be bothered doing anything else with it like changing the locks etc and now the passengers door locks, I can sort out the manual lock another day or forget about it.
So that went well-ish.
The timing belts done and timed correctly and the thing runs very nicely. It’s stupidly loud without a back box.
Only issue is the aux belt, it doesn’t fit at all. It’s a genuine Renault one for a AC car and it doesn’t fit. The length of it is 1662 but the one that came off it was 1665 which is very confusing. I need to look into that. Issue is we put a hole in it trying to get it on.
I really didn’t find it that hard at all, the other people with me agree. One of them says they are easier than a Corsa timing chain.
In the meantime, I’ve put the bumpers back on and built up the rest of the car. I know I’ll have to take some of it off for the Aux belt but I don’t care too much. I always put the L plates on too see how they look. I can’t imagine there’s been many 172s that have worn L plates.
Is what my thump pointing too meant to be loose? I tightened it and it stopped the spring? If that’s what you call it, from moving. It moves a bit on the old tensioner but doesn’t loosen the bolt. Here I loosen it a bit, it then moves and thus loosens the bolt.
Not a huge fan of an aux belt on these already.
Still having issues with this bloody aux belt , bought another jubilee that’s completely compressed the spring. It will not go anymore but the belt is still a decent way off the alternator. Anyone have any ideas, I haven’t tried walking it on the crank yet that’s my next move with it.
That crank pulley is fine. Its an OE matching part mate
The jubilee needs to be a decent one, and when you compress the spring make sure the ram inside isn't getting snarled up and stopping. Try and do it whilst it off the car so you can make sure it's compressed enough (make sure you have your bombsquad suit and safety squints on)
I wouldn’t be surprised if the jubilee is absolutely ruined inside after me getting impatient with it and gunning it up. I used a Halfords 90mm - 70mm one, half temped by the ‘make your own’ ones too get it perfect.
