Windows Guru
Car  Clio 1.4 16v
I have a second huge hard drive, is it possible to change the location of the 'My Documents' folder from my Windows drive to my redundant second hard drive. But making it so that all the shortcuts still work??
yes it is possible, simple copy it over. you may have to edit some "save file location" in programs e.g. msn for saving recieved images. its a simple task
Yeah, I know I can copy it, but I want the Desktop and Start Menu shortcuts for 'My Documents' to still work
Try this (backup your registry first!). Open regedit, go to the following key
HKEY_CURRENT_USER\Software\Microsoft\Windows\Currentversion\Explorer\Shell Folders
Here you can change the location of common windows folders. "Personal" is my documents, you should be able to edit this key and move my docs to the new drive.
Right click My Documents
Move the target to the external drive.
That's how you do it :p
It moves My Documents to wherever you want, and the shortcuts al point to it.
You can move Documents and Settings, but that needs a registry change for sure if I remember.
Well, if searching is too hard, I wouldn't suggest moving Documents and Settings.. :p
It'll take longer than a search on Google, heh.
I know, but i'm prepared to waste time doing something useless, but at the same time constructive, google searching on the other hand is just plain useless
"Results 1-12 of 19,355,574,346 took 0.7 seconds"
every sinlge one of them shite
