Get numerous lights on my dash wen driving...?
Starting from this morning (When I set off for college) was just going down the road in first gear and I got like 3 lights showing up on my car and I could hear clicking at my right hand side (Like when I turn my automatic lights/wipers on). Could there be a problem with my ECU or something like a faulty wire on my sub and amp in the boot? :S
ok ok jus drove down the road and went over a speedbump quite fast and it made my sub bounce in the back and my headunit went off and my car juddered like mad! Bad wiring..... or sumthing.... Im shittin it! lol
  ur megane r26
ok i have a similar problem, my headunit flicks itself off, turns onto the radio and does a number of other different things when i press the pause button, what is all that about, it does pause but not straight away however this doesnt happen every time i press the button
I used to have a similar problem actually with just my headunit but this was from the wrong stalk adapter being fitted. Some dodgy place in Manchester said they werent sure so they jus stuck a random adapter in lol
Its the UCH relays clikcing were the wipers on auto as the relays click onon on auto setup when there turning the lights on and off.
ok ok jus drove down the road and went over a speedbump quite fast and it made my sub bounce in the back and my headunit went off and my car juddered like mad! Bad wiring..... or sumthing.... Im s**ttin it! lol
More likly the unit switched of to protect itself.
Wiring loom problem dash off or pull the radio out the wires might be visiable which are the problem or not plugged in correctly.
  VX220 Turbo
have you insulated the remote turn on wire for your amp properly? this is a common problem with people putting in amps and not using the correct connectors for the blue and white wire, it could be shorting out behind your dash
  visualize whirled pe
^^^ what they said
It's almost certainly a relay if there is clicking heard, which can happen if a short is found in the circuit. Water ingress, a bad earth or (prob more lightly if it's after market radio) something shorting on your HU wiring. Any connections to this should be checked.
