anyone got any pics of 182 manifold on 172?
Car  S2 106 GTI
need some pic's of a 182 manifold on a 172, under the car shots would be good!:) just want to see how its all put together.
172
182
182 manifold looks massive! k-tec said you need an adaptor pipe??
Yep pipes are in the wrong place as you can see the 172 cat won't work on a 182 manifold. A 182 rear exhaust is in a wrong place so no used a 182 cat on a 182 maniofolf with a 172 rear eaxhust system.
Youy cna cut a pipe to fit. Andyman on here did some pics reconetly show what you need.
so what do you actually need then? the 182 manifold, the connector pipe, and a 182 cat? don't want to be buying a whole new exhaust system! :(
182m cat cut to fit or get a piece of metal pipe made to fit.
a mechanic told me that if you take the air filter element out it allows more air into the engine which lowers emisions, possibly allowing you to pass the test
He has some sence in that bit if you suck up and dirty since there no filter there you could wreck the engine.
