bonnet catch
Car  ST
ok I pull the leaver and nothing happens bar a click at the actual catch, so the cable is still pulling something
How do I get the fucker open?
I would get someone to hold the hold the leaver open and then try and lift the bonnet. If the bonnet opens then it will prob just be the spring that has broken
is there still resistance from the lever when you pull?? (ie the cable hasn't snapped or anything??
Ask some-one to lift up the bonnet whilst you pull the handle as the spring has probably gone :clown:
worked out I had to push down at the same time as releasing it inside, so now a two man job to open te bonnet lol
You have to practically jump on the bonnet of my dads astravan before you can get it to pop.
