KTR front and rear brakes upgrade
Car  Golf R soon...
Any one ever bought the KTR uprated fast road front brake kits and KTR uprated rear brake kit!
Need to some new brakes but I also want something to look good behind my new trophy wheels!
wouldnt bother spending any money on the rear brakes to be honest, as they dont really offer you anything, and they're tiny so regardless of what you do they still look silly lol.
as for the fronts, ive never used them myself, but they do look quite good. considered the brembo max discs with some branded pads and braided lines?
yh iv had them fitted to my 172t!
and the do look alot better!
iv gone through 3sets of pads with them and they have not
worn out!i use green stuff
im going for a 4pot conversion next from gdi.
the kit from willwood
Stevo, do you have any pics of the front and rears, just fancy a nose:rolleyes:
I think my rears will need changing as I have done 36k since they were replaced
Right Daz the setup you are talking about is what I have had on my cup for about 3 months after purchasing a set of stainless steel brake hoses from k tec racing and being very impressed with the way they perform i.e helping me brake quicker i thought imagine how much better I would be stopping if i upgraded the whole brake system. Now ppl are right in telling you that the rear brakes dont do alot in fact about 10-30% from the rear do the work if that. But I thought why do half a job so ordered cross drilled discs all round and greenstuff pads on the front with kevlar pads for the rear and when arrived I found out that the rear pads were EBC heavy duty pads. After running these in for about 200 miles I then took the cup out for a real test run and f**k me im nearly going through the windscreen everytime I press the brake pedal and seems as i havent got a turbo or throttle body conversion (YET!!!) i really cant see the point in getting 4 pot brakes.
Mark
I,ve got their rear setup e.g Cross drilled discs and ebc pads. They've been on for about 6 months and don't look very new anymore. seem to be ok, but as everone says the rears don't do to much.
I run the WP Pro 310 kit from prima on the front and they work a treat but are very noisy.But lasting well.
Actually the car now is over braked. The ABS is always trying to sort its self out.
Hope that helps with your purchase.
Thanks for the replies guys!
Can't decide between brembo max carbon discs on the front and renault ones on the rear on just get the whole KTR kit.
Just heard things about drilled brakes cracking!
I also want something that looks good as well
Whats the cheapest 4 pot brake?
i put ktr big brake conversion on my mk1 ph3 rsi jus using standard calipers after couple months the discs warped quite bad and ktec were pain in the arse about i wouldnt buy ktr ones again..id go for brembo or summit better then u know its quality
I've got the k-tec uprated discs all round and ebc green stuff. the brakes are awesome no other word for it, i'd say money well spent.
KTR brakes all round, including pads, cost £380.71.
The package I want from Yozza will be £410, which is the standard pads and rear discs from renault @ £165.00, something a little special on the front :cool: 2 x Brembo High Carbon 280mm Front Discs, Front Axle Set Pagid Blue Race Pads and 4 x Moquip Stainless Steel Braided brake hoses.
Which one do you guys reckon?
well you're compairing a Pagid Blue race pad (most expensive pad on the market, and we sell it the cheapest) to an EBC "kevlar" or green pad (cheapest 2 EBC pads available)
you figure out the rest ;)
Im looking at about 450 for a 4pot set up. Calipers, lines, fluid and pads + Brackets...It's in development just now.
Fred, you may well be a few pounds cheaper but we do have our own premesis to pay for. We also have Renault trained mechanics and a fully equipped workshop in which to carry out the work. This does not come cheap so ultimately our labour rate may be a little higher. Its also very expensive to live where we are so staff need paying more (which is a pain!!).
Pagid blues ar superb pads and we use them on our Clio turbo. They are expensive but they do work well, the can be fitted with any of our discs.
Stevie, soory to hear you had problems with the discs on your big brake kit. Warping is not a problem we normally see and if there is anything I can help you with on your 172 please let me know.
David.
good to see you back on the forum David! its been a while since i've seen you on here
If all goes according to plan we will be alot more active on here. We have a new sales manager and one of his roles will be to be more active on the forums.
David.
