Lowering help needed for novice!
  E92 330
Basically i need help with lowering, can anyone explain what the following terms mean?
-*- coilovers?
-*- dampers?
do i need these to get low?
what are the benefits, and down sides?
would i stil be able to put alloys on was lookin at 15/16" deepdish?
  VW ....
coilovers are the whole unit eg spring & damper combined - superb handling ,can go very low (adjustable) ,but not cheap
dampers are the shockies
as above coilovers will get u low but springs do also as a cheaper alternative ,depends how low u want to go & how much mullah u want to spend .
as for alloys don't see why not ,just depends what offset they are .
  Leon Cupra R 225
if you can afford it coilovers. ie fk's, h&r's
if not, uprated shocks n dampers. ie spax someone like that
