Valver bearing Q
  Clio 16v
G'day
ive got to change the bearings in the front...where are they?
are they pressed into the brake disk???
is the a step by step instruction to do the job?
cheers rob:rolleyes:
  CB600FS
No there in the hub on the fronts. You need to remove the hub, someone posted a guide up not long ago in your other thread have a look there.
  S2000
yup, best way is to remove the hub yourself if you can and take it to a garage. Usually they will press the old one out and a new one in for a tenner, so only about £30 all in to replace the bearing as it shoudl only be about £20/25 for the bearing.
