What engine Oil and Gearbox Oil
Martin_172
Whats the best engine oil and the best gearbox oil to use in a 1.6 16v was thinking about this royal purple stuff (think that was what it was called) but cant find it anywhere to see just how expensive it is!
i can get a good discount on millars motorsport oil too?
any ideas
cheers
  BMW M135i
Gearbox takes 75w80 and I use 5w40 in the engine in mine. I changed the gearbox stuff with normal castrol stuff and it made a massive difference.
G_F
  BMW M3 & Williams 3
Its a piece of piss to change g/b oil, it must do your head in changing a wheel!! lol
  AMV8, Mk1 Golf
its not easy when you have massive air filters in the way, and a skid pan underneith, but your cars so low you cant get a jack under it
G_F
  BMW M3 & Williams 3
Well in that case, remove the filter and drive your car on to blocks of wood or similar so you can fit a jack under it, or buy a decent jack
http://www.machinemart.co.uk/shop/p...-bottle-jacks-transmission-jacks/brand/clarke
  BMW M3
I wouldnt say changing gearbox oil is "easy".... patience is needed and small hands.
Did mine last week for the 1st time ever and ended up removing air filter to gain access. Then you have to some how find a way of getting the oil in (dodgy angle and small hole) Luckly i fould something perfect in halfords.... a big long funnel and moves at the end.
Got a face full of oil too cause of the wind lol
I used silkolene 5w-40 for engine and i think silkolene 75w/90 for gearbox.... dog in the morning but lovely once warm.
  Chocolate Bar™
will be buying some millers gearbox oil for mine as soon as my car comes back. also a rather poor excuse to have a blast to wrexham to pick it up from demon tweeks. there loads of places locally that sell it but dont tell the missus ;)
think the millers is £50 off DT.
also quite like elf excellium 5/40 engine oil, but will try some silkolene pro s this time to see if it makes any difference.
gear box oil is hellishly expensive
Depends what normal oil you use I use expensive normal oil so the gearbox stuff for £40 cheaper than the engine stuff.
Demon Tweeks will do it for £44 or sofor the Millers 75/90 thats the stuff I've always used.
Royal purple is £50 or so.
Its good to change the oil bit I don't like the cahnge any mre just makes it more fluid and sloppyinstead of being like stiring porridge.
