Still having trouble
Car  Clio 1.4
I got all my wiring from the boot to the passenger foot area, but getting the amp connection to the battery and the head unit is being a pain in the arse anyone able to give me a dummies walk through?
many thanks
Gammer
Mine is running in under the seats and down the passenger side, not 100% where it goes from there but I could find out
Which Clio ?
Assuming its a p1 or 2...
You can go through the grommet by the bonnet pull cable and connect to the battery. Don’t forget to put a fuse in-line.
For the amp trigger you will have to pull the set and connect up to the output which comes on with the set (normally a marked blue wire) be careful if there are two, as some makers have one for an amp and one for an electric aerial which turns off when you select tape or disc.
Alize 2003 1.4
ive got the wires running down the left side (passenger side) and now i cant find the gromet to get it to the battery, and i have the standard Clio Headunit and cant connect the wires from the amp to that :S
Well, the grommet is there follow the bonnet cable.
The head unit has a pin for the amp output its, pin5 on the connector nearest the back of the set.
Bonnet Cable ? :S
honestly im such a simple minded fool i dont know
erm i tried to get the head unit out today with some home made pins from metal coat hangers i failed terribly :(
any advice? hints or tips?
With the greatest of respect......I think you need help before you do some damage. :nono:
Bonnet Cable ? :S
Go to halfords and buy some removal pronges for your stereo, it's not rocket science.:nono:
