cold air feed in grill fitted at last!!
Car  53' 172 Cup
bet its crushed, which imo defeats the object.... nice that its black mind
looks nice and subtle that, where did you get it from
cheers guys. got the piping from Venair, and the ram pipe off ebay (regal motorsports i think). sprayed the ram pipe black so it doesnt stick out like a sore thumb! was pretty simple job actually...had to take the bumper off tho....
all good. i had sumthing similar in the bumper of my old mk1. was gr8 till it sucked up an entire pudle when i drove through it :P watch out
looks proper good andy. ur pipe looks lot bigger than mine - wasnt sure how big to go, its such a tight fit. (btw did u spray ur wheels or are they anthracite?)
mine was the pipe which came with my viper when i had one. its a bit bigger and only just fits lol
the wheels are pc pewter which is a bit like anthracite but with a bit more flake in them :)
How do you take the bumper off? I need to do mine to adjust a bracket!
there are a few bolts inside each wheel arch, some on the undertray and u need to unclip the upper grill. you have to pull the side by the arches outwards and it should all come off (hopefully) lol
its not too hard mate. you will need someone else with you probly tho. just a case of undoing all the screws under the arches (take off the lining) then there are some bolts iir underneath the bumper (plastic cover under the car is bolted to the bumper) if you get under your car ul see what i mean...! then there are metal clips on each side at the arch whcih u need to take off - then with some force pull the bumper away. itl probly suddenly come away so be ready to stop it hitting the floor wen both sides come away.
