oh ffs dan youll want a nice discrete towbar next, do you have a panama hat for the shelf too.....
Dan,
With the wheels off, can easily fit two mountainbikes into the back of the clio.
Just fold the seats forward and put a sheet down. Can fit the rest of your cycling gear in too.
Will spend more time fitting the roof rack, and then getting the bikes onto it and strapped down, than you would popping em in the back.
the thule roofrack i have takes less than 20 seconds to get bike on or off. Only time consuming bit is fitting the roof rack which takes no more than 5 minutes, longer if you clean the roof first.Dan,
About £25 off ebay or £75 from Renault iirc.
Plus fitting!!!
They're a permanent fitting.
They have to drill holes in the roof and bolt them on.
Dan,
You dont have to drill holes with the Renault rack. They come with a key the goes in the side that you turn to lock them onto the roof sills, the more you turn the key, the tighter inwards they go. Its a very good fit imo.
As said by others, defiinitely recommend Thule rack. Fits perfectly and holds bike really well. Before that had a Paddy Hopkirk high rise rack from Argos! Worked fine but blocked the rear wiper (right pain in the arse if you forget, left your wipers on and wnet into reverse!!) plus annoyed me not being able to use the boot once it was on.
