One red light of doom !!!!!!
Car  Mk1 MX-5 next summer
Umm bottom left red light keeps coming on.
when i boot up 360 it comes into the first screen like the xbox logo then goes to the black error screen.
E79 comes up.
i have unplugged it all inc HD and put it back in, tried it standing up.
nothin. just wont f**king come on
i e-mailed customer support.
I had 3 red lights last night. Phoned them today and its being sent back for the 2nd time.
Go here: www.xbox.com/support and see what it says about 1 red light.
Great consoles but they break too often.
I got this earlier.
FATAL ERROR 23--00*7&7777
BUY A PS3
Then everything went blank.... ;)
In reality my bros has NEVER gone wrong and hes a games junkie!
my mate just rung me and his crashes when the 360 logo appears on boot up!
when you send it off is it free, hes only had it 5months!!!or can u go back to Game?
i bet mine goes soon!
I have been considering getting a 360 but the horror stories are putting me off.
They are great fun but mega unreliable. The amount of money I have spent vs. amount of fun hasnt been worth it really. If my next one comes back broke I am going to cut my losses and get rid of the thing.
i want one only to get the guitar heroes 2 game, but also the horror stories are scaring me. my ex got one when they first came out and it was great, but he didnt like it and sold it back to game and got the old ps2 back out of the cupboard.
I had 1 Red Quadrant before - bottom right quadrant.
Try removing the HDD then booting.
www.xbox-scene.com said:
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
--==SECONDARY ERROR CODES==-
The specific type of hardware failure can be determined by a "hidden" error code
  • Turn the xbox 360 on, and wait till the 3 red lights are flashing.
  • Press and hold the sync up button (the small white one), while holding that button press the eject button.
  • The LEDs will now blink the first number in the code (as described below).
  • Release the eject button and press it again.
  • The LEDs will now blink the second number of the code.
  • The LEDs will now blink the third number of the code.
  • The LEDs will now blink the forth number of the code.
  • The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
0023 (not yet known)
0101 (not yet known)
0102 unknown error
  • though it's most likely GPU related literally means the console does not know what is wrong. possibly a short or cold solder joint somewhere. So far there is 1 major theory for what causes most of these errors is that the Ram, CPU, or GPU are not soldered properly to the mother board due either to poor manufacturing or excessive heat up and cool down cycles that stress, weaken and eventually break the soldered connection.
    There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced. I have also heard of limited success by simply switching the AV cable from "HDTV" mode to "TV" mode.
0103 CPU Error/ CPU Overheating - see solution for error 0102
0110 Memory Error / Memory Overheating - see solution for error 0102
0200 (not yet known)
1000 (not yet known)
1001 (not yet known)
1002 (not yet known)
1003 Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
1010 Hard Drive Error, Can be caused buy a corrupt or missing eProm.
1011 (not yet known)
1012 (not yet known)
1013 (not yet known) possibly a dashboard update error
1020 (not yet known)
1021 (not yet known)
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
1023 DVD drive not connected, connect DVD drive to boot
1030 (not yet known)
1031 (not yet known)
1032 (not yet known)
1033 (not yet known)
1444 and up There is no "4" in the error codes four lights is a "0" go back and check your code again.
should be able to take it back to game as game will replace it if its still within its year warranty.
im waiting for mine to come back from microsoft...£85 down the pan! :dapprove:
You paid up?
Ive heard they dont really ask for proof -apparently they quote £65 and charge £83 as well!
well i don't want to curse mine but i play it a lot (11k gamerscore)...never once had a problem at all. good luck in getting yours sorted though
ive had 2 since laucn and never had a problem with either, none of my friends have ever had a problem either. its just everyone will post when it goes wrong but nobody is going to post saying "my xbox didnt break today"
My x-box didnt break today! Never had any probs and neither have my mates. I think the problem is simply to do with a batch of consoles rather than the 360 itself. This update only affected certain consoles and the chances are if you've had your 'box for over 8 months or so with no probs, you'll probally be ok.
you phone up support, they email you a UPS label, you ring the phone number arrange collection, the naked xbox in a unbranded box, stick the label on and they collect. Don't cost you a penny, just a bit of time.
>15 days later you receive a reconditioned one, I got mine back last week.
mines sorted now yess..
said it was a HD problem.
anyways how long does the manufacturer warrenty last, or shoulr have a registered it.
mine sometimes flashes with the right hand corner red led, but switch it off then back on and all is good
doesnt cost a penny if its within a its year warranty!
Oggy172You paid up?
nah they ask for proof!!
nah thats crap, they quote 123 euros which usually works out around £85.
Mine fecked up a couple of days ago, sending it back asap.
Its out of its one year warrenty but they agreed to do it for free.
I'm in a dilemma now, do I cut my losses and sell my entire setup for the ps3 or not.
Reasons for - it may/will happen again and I dont want to spend £85quid getting it sorted
- Its so fecking noisy and the playstation 3 is silent
- Gran Turismo 5
Reasons against - Forza 2 and Halo 3 are both due out and tbh I really like triggers on the joypad for driving games etc.
- Won't get the money I ideally want, in all probability.
Hmm, anyone in the market for a 360 then lots of games and extra bits PM!!
