Changing Wires
Barron
Car  Turbo S,Exige,R5,182
Im putting new Component speakers in the front but i would like the change the wiring and replace the crap renault wires. Is it a hard job to thread the wire which i have got with my alpine components through the tubing connecting the door and the dash?
Thanks
Carl
You will need to take the door cards off then remove the plugs that connect the rubber cable grommet between the front edge of the door and the A post (you will need a Torx driver) you will see there are spare holes in both half of the plug and socket.
Use two of the lower holes and drill them out carefully to the size you require (on both halves), and feed the new speaker cables through before re-connecting the plug/socket.
Make sure you clip the new wires out of the window winder motor and regulator before re-fitting the door card.
hmm you got any pics because dont fancy starting it if i think it may be too much hassle :S
Have a look in the technical guides, I think there is something there, Id look but I,m a bit up to by neck atm.
