Just changed my gearbox oil.....
  Clio 172
.....and boy was it dirty! Absolutely filthy, so much dirt in it, was told to expect it to be relatively clean but it was a black cloudy solution! Mines only a 02reg on 39k miles! Fully recommend doing it.
DrR
  VW Golf GTD
where did you get the copper gasket you need to replace from?
  Clio 172
Used Comma 75w90 - £17 for 3.5litres
My sump plug was leaking hence the change. When I unscrewed it it was only finger tight and the washer was in perfect condition so just reused it, else I had some spares from work.
Bloody hell black ? ?
Aint like the miles are well high neither. :S
Where is the drain plug and fill plug for Gearbox ?
Are they above each ?
I.e . Fill pug higher than drain plug ?
I fancy doing this ? ?
Did you have to attach a hose to a funnel to direct it into fill hole ??
Is it just a case of filling into fill hole till it comes out and then stop and replace plug ? ?
  Clio 172
3.1 litres.
Fill plug is a butterfly plastic nut on front, drain is a 8mm square socket plug on the bottom.
I bought a funnel with a long flexi bit attached that went straight into the fill plug.
Easy
Ok cheers guys...
I was gonna use Milers TRX 75W90 Gear Oil as i have 4 litres left from topping up my lst car ;).
Would this be ok to use ?
As in spec 75w90 ?
  Clio 172
notice any difference at all?
Apart from 2nd not being so slopping no difference at all, maybe a little smoother when cold but we haven't really had any cold mornings to test this.
Even for just removing all the cr*p in there though it was worth it for the few quid it cost to do.
