Surely certain years/engine size usually have the same spacing? I can't really check until i've got it off the car thou? bit hard to measure 2mm difference when its still all attached![]()
Higly likly yep.bloody renaultsis it easy enough to measure then? Was just thinking if the ruler or whatever is at a slight angle or something its only 2mm so could be easy to c**k it up? so say an RSI has got a high chance of being 54mm?
Also any quick way of checking if the bearing is ok?
