Hub spacing on mk1s?
Car  Valver
Getting another hub for my valver, which is 54mm spacing (akaik?) but the scrappies round me only have 1.2/1.4 etc so which ones would have the same spacing as mine so 54mm?
Surely certain years/engine size usually have the same spacing? I can't really check until i've got it off the car thou? bit hard to measure 2mm difference when its still all attached :(
You cna tell the difference.
Usualy the larger engine have the bigger ones but theres no fast rule with Mk1's.
bloody renaults :( is it easy enough to measure then? Was just thinking if the ruler or whatever is at a slight angle or something its only 2mm so could be easy to c**k it up? so say an RSI has got a high chance of being 54mm?
Higly likly yep.
Also any quick way of checking if the bearing is ok?
Jack the car up and try shake the wheel from the 3 and 9 and 12 and 6 positions see if there any play in it.
