rear spring help please!
Car  Silver Clio 172 Cup
OK - I'm trying to fit sportlines to my 172 cup. It's all standard at the moment. I Started with the rear because that's easiest. Followed the fubar guide to the letter but I can't get the rear beam to drop down far enough to get the springs out. I tried loosening the top mounts for the dampers as well but that didn't help.
I'm stuck - any ideas anyone?
Tom
Undo the bolts which hold the rear shocks in place to the rear suspension under the car and the rear drops. If it doesn't giver it a bit of a push and it will go down.
you have to have the car surpored on stand and undo both sides to get the springs out make sure you surport the beam though with a trolley jack or something.
Have unbolted the damper most of the way but not fully (as on fubar's guide). So do I need to unbolt it fully? If I do then is it easy enough to bolt back together?
No idea what his guides like but there one 17mm bolt on the bottom of each damper attaching it to the rear arm just unbolt that fully on both sides the the whole rear axle drops (again might need to give it a bit of a push) then fit the springs. Then lower the car so the rear dampers bolts are in the right postion to bolt them up to the rear suspenson and bolt them up.
Rears are dead simple to do.
HOW MANY TIMES!!!! they're 18mm edde, you should know that by now!!! ;)
undo and REMOVE the rear lower shock bolt on both sides (18MM!!!!!!!!!!!!!!)
jack up rear of car on sills (plenty stong enough)
rear beam will drop
rear spring will fall out
easy peasy, if it takes more than 20min, you've cocked up big time
rear beam will drop
easy peasy, if it takes more than 20min, you've c**ked up big time
As above, the rear spring should just lift out from the bottom of the spring, grab it with both hands and pull it towards you.
