ordered ktec group 'n' remapped ecu - but not sure if i done the right thing!
Car  Clio 172 Cup
ordered ktec group 'n' remapped ecu today (exchange unit) - but not sure if i done the right thing!
would it be better to have my car 'inividually' remapped!?
mods
itg maxogen kit
straight through decat
ktec exhaust
angelworks manifold
this is so confusing!
I will be making a trip to rs tuning for one of their remaps after i have fitted my induction kit and exhaust because of the reputation they have on here.
It'll be fine thats what i was running on my Cup (a bb tuning one mind) And it had 172's, and a 182 i came across. RS tuning maps arent specific to the car, as in they are not R/R mapped iirc? I Presume he will just tweek it for certain mods, but the map will be generic i'd have thought? Correct me if i'm wrong?
had mine done at rs tunning all is good .
can feal the difference in the pull all through the gear range .
no rolling road at ktec asked today on phone, they take the car somewhere else to do it.
have booked mine in with Paul at RS tuning next week on his new rolling road for a PROPER remap: before run, car tweaked to max power, after run.
If ktec have not sent the item out will be cancelling it, if they have sent it will be sending it back.
Ktec are still cool people, have bought quite a bit off them in the past couple of weeks.
Yesterday, 19:58 #119 pmurray vbmenu_register("postmenu_2894041", true);
Car: RS Tuning 300 Trophy!
Re: Leeds's First Dyno Dynamics Dyno!!!
Are you wanting one of my standard maps to suit them mods or some fine tuning done on the dyno also?
Paul
Told you so. His standard map is like a generic grp n, but is flashed on your ecu rather than an exchange. If you want a live map on a R/R thats ££££££ For the mods you have, i'd say a grp n is fine, wont be much difference then pmurry's imo.
Paul
Our standard map is not an off the shelf generic map. I have spent hours and hours on dynos with different cars and different combinations of mods so i can accuratly create the map for nearly any mod from scratch.
Paul
Nup. I thought the grp n basically raises the rev limiter etc, gives you a bit more pull, but doesnt do much else. Its best suited to standard cars.
Rst have different levels of mapping to suit different combinations of mods.
Paul
Paul
I've got a 172Cup with matched inlets from Angelworks, a Green panel air filter and a de-cat pipe on a full magnex stainless exhaust.... what remap can you do for that, what will be the increases be (both in BHP, Torque and MPG) and how much will it cost please
cheers :star:
£295 for the map, if you want any dyno runs they will be extra. As for the increases. You should see 10hp and 17lbft, ish!
can't wait to get my car to you.
bit peed off at the moment as some cyclist rode into it today and scratched the f*** out the bumper and put a huge dent in the back!
:mad: idiots, Funnily enough that happened to my mate the other night! Made a good mess and the bloke got up and ran off!
See you then
Wrong chap. You get a nice increase in midrange too. I actually believe the P Murray use's/ based his map from the guy who made the GRP N (henk?) I also believe that yes, RS tuning can tweek/ change this mind :)
I believe Pauls map will be better than the GrpN... but that doesn't mean the GrpN is bad..... I had one for a while and out of ecu/inlets/exhaust/maxogen it made the biggest difference by some margin.
I never use other tuners maps, all maps are from the original.
Paul
I think i can get you in actually
Im not based in the UK. is there any way you can send me a remaped ecu depending on my mods, which are the Viper k-tec induction kit and a decat pipe. I could probably send u one and get in tuned then get it shipped back. is that possible. Thanks
Abdulla
No problem. Take a good picture of your ecu and send it to me and i will see if i have it in stock. Sometimes they have slightly different ones fitted and it causes problems
alright, ill pm you as soon as i do that. Thanks for replying. Where are you based in the UK, i might be visiting englad some time next month so if your close, maybe you can send it locally.
Abdulla
