is this a 172 plenum or 182 plenum any1 know?
  racing blue 182
hello, i was thinking of buying this but don't know if it will fit my 182?:S
does any1 know?
thanks
sorry i cant get the picture to come up! how do you get pictures up?
[/IMG]
that i beliveve is a 182 plenum mate the 172 has the coil pack plate all as one part the 182 is bolted on
Me neither, to confuse things more that part number on it is the same as the 172mk1 plenum. Did renault just modify there existing tooling and not bother changing the number?
i'm sure there is a breather on the top right hand side of the 182 version (round the back)
just looked at my 182, the breathers are in yellow ;) Things we do ;)
so as above it looks like the one you've posted pics on is for a 172.
both identical apart from the extra breather on the back of the 182.
and the 182 has the mounting on the back in a slightly different place.
can't see why using a 172 manifold on a 182 would be a problem though anyone else know if this is an issue?
Afaik , the manifolds are the same on the mk2 172's and the 182's . Its the plenums that are different and are not interchangeable .
