172 Speedo Sensor part number??
I think I need a new one.
BTW, do you know if the mileage counter will work if the speedo does not work??
  BMW M135i
No the miliage won't go up, although you've got a Ph2 FF right? There isn't a speedo sensor as its done through the ABS.
Only the Ph1 and the 172 Cup have speedo sensors on the gearbox.
??? Mine is MK2 172
What should I do if I found my speedo sometimes does not work?? Change the ABS sensor??
And how come my garage friend shown me a speedo sensor last weekend?? It is a tube and looks a bit like a plug lead. Also, he told me the sensor is locate at the back of the engine near the exhaust manifold.
Pls help me out with this??
  Trophy Turbo :)
yours shouldnt have one on the box if its a FF...
I have a brand new one from renault that i bought last week but then relised it wasnt for my car Opps.
ill take a photo for you and i have the plastic insert that goes intot he box too. If its the same and you want it i will sell you it at a much discounted rate i paid about £34 all in ill sell you it for £25 posted fully boxed with the recitt ;)
Ill post pix tonight
Thanks and I will take a pic of the sensor area I talked about tomorrow cos it is midnight in my country now.
I use Paypal. No worry.
  BMW M135i
??? Mine is MK2 172
The Ph2 100% doesn't have a speedo sensor on the gearbox, if it was on the end of the gearbox then thats the reverse light switch.
Tbh i'm not sure how to progess on it really, theres an ABS sensor on each wheel and I can't 100% remember which one it uses. And if the ABS works then I can't see a problem with the sensor(s).
I think Edde said some early 172 MK2 has the sensor. My Clio is 2001 MK2.
Maybe I should give my garage friend a call tomorrow to make it clear as well.
Thanks!!! Will PM u later.
Here is the pic I took, sorry, it is by my mobile. But as it shown, I have a sensor on top of the gear box. My Clio is 2001 MK2.
