Vectra 1.9 CDTi SRi 150
Having sold my FK Coilovers I have put traditional shocks/springs in the form of the Koni Kit. Like other suspension kits i've had in the past they arrived scratched due to poor packing and an industrial quality paint job, so before fitting I gave them a further 2 coats of Machine Yellow to help keep them looking good. I also had some Renault parts missing so had to buy 2 strut top kits from the stealers....ouch...£££'s. Painted top spring plate with 2 coats of silver Hammerite. Plenty of copper grease used in assembly too.
This was also the ideal time to re-paint my Calipers as they were looking tatty and fit my new Tarox G88 front discs and Green Stuff pads. Also, finally got around to fitting my Braided Lines that I got in the group buy. So this was also the ideal time to change the brake fluid too.....we won't say too much about this as I c**ked it up and need to get more fluid and do it again
Pics below.....
The notoriously messy rears brake lines....fluid goes all over.....but an easy job...
Rear calipers painted, need to get some rear discs soon......rear springs and shocks fitted prior..
Front suspension fiited and Front calipers painted in situ after removing old discs/pads and a good clean with aerosol cleaner....£3.50 from Boyes
Discs and pads fitted....
Wheels back on.....
Back on the deck and happy with the ride height, quoted at -30mm. Not much different from my coilovers as I had the pretty high as I didn't want arches rubbing.
Just gotta sort my brakes out so I can take her out for a blast and see how it handles.
Wheels back on.....
