How to remove this scratch?
Car  Z4
I've had it for a while now, and I didn't know how it happened when it did! I'm guessing some t0sser brushed my it or something.
Anyway, I can't catch my nail on it which is good, but it doesn't want to polish out either. What products can I use?
Obviosly not a clio, but I'd appreciate some feedback as this part of the site is quality!
Failing to catch your nail in it is a good sign and it should polish out with a bit of effort. What polishes do you currently own?
Looks like a scuff more then a scratch should be pretty easy to remove with a PC and some carlacks 68.
I haven't tried any anti scratch products, just literally a hard hand polish with megs etc! But with no results tbh.
I'm not going to touch t cut as it's metalic red and I'm just too scared! I thought about scratch X but it's possibly too mild?
might need a wetflat
possible.
Tho first try the Link Rich Gave or Meg ScrathX.
if you have no luck after a while and a very dead arm, As FM has said a wet flat may be in order.
It is however hard to say at all from pictures.
My dad had a similar mark up the side of his old car which reduced by using scratch x but was still visible. As I didn't have my PC then I didn't have the Menzerna IP which might have had more effect, he had it mopped in the bodyshop in the end which did the trick nicely.
I had similar scratch, used Meguires (sp?) Clay to clean the length of scratch then Scratch X, took it out nicely with a bit of elbow grease and patience. My car is Silver though so it's possible it's still visible under extreme light but I can't see the scratch anymore.
Well I'm not overly fussed as I'll be selling the car pretty soon anyway! It's just one of those things I've never gotten around to as the rest of the car is spotless and I dont want it putting off potential buyers. It's not even that obvious, just annoying when you do see it!
Is there anyone in the Norwich area with a pc?
