removing acoustic valve on 172 cup
Gaz_
  Extreme mode
Arch liner out, pull off the vaccum hose and BLANK (important) Remove all cold airfeed piping, disconnect and tape up multiplug. Is it worth it? Well it saves another KG or so, i removed mine on my 172 cup and my 182 with no problems.:)
  182 has now gone!
I have had it taken of my 182... Think it took about 10 mins or so (my boyfriend did it!!!)
  Saab 93 Aero Wagon
I found it made mine less jerky during gearshifts at slower speeds.
And anyway, its only a butterfly valve that opens and shuts.....one less thing to restrict any airflow can't be bad.
  RenaultSport clio 172 mk2
might sound like a daft question but whats the acoustic valve ?
There are two ducts feeding air into the air cleaner. One is an open pipe feeding up into the bottom of the air cleaner. The other feeds into the side of the air cleaner and has a valve in it that's connected by a vacuum tube to the intake manifold so it only opens at highish revs and throttle openings.
Having only one small pipe feeding air to the air cleaner at low revs and two at higher revs and thottle openings would definitely keep the intake noise level down in normal use like on the motorway. And a knowledge of intake design suggests it should (though its not proven) improve torque a little at lower revs. All without restricting maximum power.
Of course a lot of people on this forum don't want to keep the intake noise down. They think noise equals power, that noisier is "better", or at least that other people will think their cars is more powerful if its noisier. And they think that taking the valve out will increase maximum power, but of course there's no difference between the valve removed and it open.
  RS RIP
Hi Gaz,
excuse me for not understanding all of this, dutch guy he !
What do you mean with KG ? And what's Blank ?
I guess i must have al look before i know what we're talking about.
  Clio 172 Cup
so fromwhat your saying having an ik fitted renders it completely use less any how
so if you have an ik fitted its useless any way yes?
mines coming out.
any one got a guide to get it removed.
