ERM HELP!
Car  E60 diesel powah
Just went outside to my car...started it up...ran for a min then completly cut out!
went to start it again nothin..no electrics are on!?
Fusebox?
its dark! cant check fuses, nothin! no dash lights, no interior lights, no xenons etc etc! wont even lock
1 in every 1000 cases an electric charge can shoot from the ignition to the ecu and blow it.
If you can find someone with the same car that you can quickly change ecu, you can tell if it is that.
If it were the ECU then it wouldn't start. Seeing as the whole things dead as a dodo i'd imagine its something else.
