Stack Dash
Car  C63 AMG, F430 & 172
Where can i buy a secondhand one from?
i bought a brand new one but tweeks said it would be ages to be delivered!
will they work with a aftermarket ecu?
yes they will, you use your outputs from your ecu to control it and as for oil temp/pressure, water temp etc they have there own sensors you fix into the block/hose etc. They have all there own wiring and plugs to do it. easy. :D
few and far between 2nd hand.
sometimes come up on Ebay.
I had one, got it 2nd hand (after Stack ahd refurbed it), never fitted it, and then sold it on ebay.
Why dont oyu call Stack and see if they can tell you someone that has one in stock?
just emailed them, show much did you sell it for?
£500 is a good price! i payed about £950! ahh well they said i will have it anyday now!
yeah sold it for £500. only cost me that, so wasnt too bothered.
Why didnt Yoz fit it??? too complicated for you boys!! LOL
I was thinkin of a Motec ECU with Motec dash when i go ITB's.
Dash is plug and play pretty much! :D
IVE SEEN THAT ECU, BUT THINK THE MODEL I NEEDED WAS ABOUT 2.7K ISH,, SORRY FOR THE CAPS ! KEYBOARD IS BUMMED
The Vx220 uses a version of a stack dash. I bought one and attempted to fit that into my corsa. However it used lotus sensors and they were ££££ and the wiring implications so i gave up. It has been done but lots needs to be rewired to get the whole dash to work.
dependant on what stack system you use depends on the price.
I am very confident with fitting and running and data logging with stack and PI dashes .
The 8100 stack is a basic road version and that comes with oil and water temp sensors and oil pressure. Speedo should be run of the left rear wheel, and you can pick up the revs from the coil pack or ecu.
