oil
Oil £50-£60 (thats based on a 5 litre and 1 litre top up on the oil recommended above)
Filter £5-£10
Sump plug and washer £1
Delivery charges (unless your picking it up local) and your probably shy of £80. As said £100 will easily cover it.
You'll only need 5 litres of oil even when you change the oil filter , that takes it up to the MAX line on the dipstick .
I asked how much oil the system takes and was told just under 5 litres. Flushing the system and topping up the system when it drinks oil and the 1 litre would come in handy. Ive always bought a topup.
Renault say it takes 5.1 litre with the filter change , i've never needed more than 5 litres . If you don't change the oil filter 4.75 litres is usually enough .
The only time my 182 ever used any oil was when i bought it new and needed a slight top up after a couple of months . I changed the oil after 6 months and it's never used a drop since . My 172 never needed topping up either .
Renault do say that they " can " use 1 litre per 1000 miles though :eek:
yeh mine has never dropped much, i would always change the filter at the same time as the oil - pretty much common knowledge isnt it
that make is the same as genuine renault one.
and im of the opinion oil is oil if it meets the requirements and is of the right grade you cant go wrong! *awaits slagging*
elf excellium 5w40
I'm looking at swapping from Excellium 5W40 due to my engine sounding a bit rattly after spirited drives on hot days. (I'm talking 40+ degrees Celcius so it may not worry most people on here! :) )
We don't get Sikolene or Millers in Australia :( so I'm looking at Motul (300 or 8100) or Redline 5W40.
Mobil stuff isnt' as good! Is mobil stuff semi synth? Silkolene is fully synth i think. You get what you pay for.
Do a search for some oil thread or a post by oilman there was some good reading in there somewher.
