Rear brake pad/disc wear
  Polo Bluemotion
I understand this is kind of an open ended question,due to lots of variables.
I know the front brakes do the majority of the work, but what is the general life expectancy of rear discs and pads??? Im upto 41k of reasonable driving, and ive just been informed that i have less than a 1mm of pad left on the back.
It just got me wondering if thats normal,late or too soon for that kind of mileage......
MarkCup
41k miles sounds pretty good to me.
I managed about 80k on mine, but then the Cup has very low rear brake bias - your DCi would do much more braking at the rear.
  AMV8, Mk1 Golf
mines on 42k and im just changing the disks now,
nice new shiney ones sat on the table just need somone to fit them
That will be 1 mm leaft till the wear marker. the pads new are only 6mm full thickness and you shoulnd't use them all the way down to nothing hence the point of a wear marker. I woulnd't worry much.
  Iceberg 172
What does the wear marker look like? (given that i'll be peering through the wheel and the grime...)
