My first go at photoshop!
Car  clio 1.4 sport
Not too good as its my first go but here they are.
Car as it is
No handle
Taken off badges and handle
smoothed everything out
Looks ok mate , take it u used lasso tool copy & paste then eraser tool ?
Try lowering it thats your next mission then colour code,
To tint your windows
Go around the outer edge windows using the lasso tool
Then to to image,adjust,brightness/contrast, and lower the brightness
Hope this helps
first attempt its ok mate, but check out ur front bumper on the origianal and your lowered one they look totoaly dif basicaly where the wheel is original pic is straight nearly and modified one is totaly curved you need to use the lasso tool more carfully and make smaller clicks round the arches etc ooh and dont tint the front window :)
Not bad effort for a first time, where did you buy the car and how long have you had it? I recognise the plate.
ye it didnt look right because i had to bring the car forward slightly before it looked on the wheels. then the front bumper looked too far forward so did some diy lol
change the rims
Try and find wheels you want at the same angle as the car Otherwise it will look a bit crap
Use the eclipse lasso tool and draw loosely around the wheel and tyre.
Then go to Select,Modify,Transform and adjust it using the grab handles Shift to skew it
Copy ctrl+c and then paste Ctrl+V it onto the image you are adding it to
Hit Ctrl+T and then transform the wheel so it is at the same angle and is the same size as the original. If need be use the Eraser tool to blend it nicely into the rest of the tyre
If the front overlaps Use the line tool and delete the overlap
Thats basicly it
http://www.digimods.co.uk/tutorials/tutorials.htm
lol ragged about was it? mine had a lady owner so should have been carefully driven althought it did have tweeters in the door so she could ov been a little girl racer!
hi. not a bad effort.
photoshop takes a while to get used to.
try http://digimods.co.uk/tutorials/tutorials.htm
it shows tutorials on how to do everything and gives a difficulty rating. Ive tried a few things and this makes things a lot easier.
also look at www.digimods.co.uk and the gallery shows how good people actually are at it.
Sam
sorry didnt realise Vern had posted about digimods just before me, wasnt trying to steal his idea.
