re map or superchip??
Car  RenaultSport clio 172 mk2
hi all. just wondering whether to re map my 172 or have it superchiped not sure what the difference is?? could any1 give me some advise plz..:o
a superchip is an adjusted standard map that you get plug and play, it will increase stuff like fuelling and timing and release a few bhp
a remap is tailored to your engine taking into account any mods you have done and will increase bhp more than a superchip because it's for your engine not just any similar engine
Daz
also look here: http://www.fastchip.nl/content/view/25/37/
Superchip is a brand of off the shelf remaps. there are various other suppliers of off the shelf remaps. the fastchip option mentioned above is a better version of off the shelf remaps.
the other option is custom maps done on a rolling road.
if you havent done engine mods like cams then i would go for fastchips
Daz
Wrong!!!!!
that's helpful
why is it wrong, please enlighten me
Daz
Wrong!!!!!
the initial post is basically correct, not sure what you think is wrong about it ? you might argue that superchips did not base their new map on the original but I suspect they probably did.
and indeed, a real remap will take into consideration the whole motor, whatever its camshafts, compression ratio, cylinder head work and so on. :)
sorry if I've missed the point :)
Superchips uk can alter a map to account for ignition retarding & AF, The did the vee and altered it to suit.
Thanks Ali,
Superchip, like every other remap, starts with a base map, then in my case we did 5 rolling roads, adjusting and mapping it to match the modifications on my car. Hence tailored to my car.
Thanks Ali,
Yeh, remap'in an NA car is rather like skiing uphill! A tedious task!
i need my adjusted again now, jeremy townsend was followin me on track and mentioned it was smokin a wee bit on down changes. Will lean it off a wee bit this weekend at RR meet.
Thanks Ali,
Yours may be a superchip but it was tailored so a remap like i stated............
an off the shelf superchip, isn't mapped it's just plug and play
would people please get into their heads that SUPERCHIP is a BRAND NAME ONLY and not a description of any form of remap be it a custom rolling road remap or off the shelf remap
theduckeatspork i think u justed ended the about 50% of all forum posts! - a few more of these & its all over.
just like to say - thanks
RSTuner, Fastchip this is what you are looking for.
Henk is an excellent guy and his customer service is second to none.
