Head light adjustment
Yup.
Adjusts the up and down movement of the lamp.
Make sure you are on a flat/level surface.
The rear self adjuster is quite sensetive......
Yes, but do it with the ignition turned fully on (but engine not started).
Right great stuff,
as since its been lowered lights seem to have dropped for some reason
Yup they will do.
We adjusted bmh.01's lights other day.
Got my car and marked up the positions against my fence on driveway.
Put his car in the same spot and adjusted his lights to my markings. Spot on now.
See if you can get someone to help you out. Saves guessing where they should be.
Good idea Has,cheers
come to think my mate does M.O.Ts so he should have that light box thing to set them right?
Nice one mate cheers
so you have to adjust when the engine isnt running but ignition fully on?so you would have to manually turn the lights on then?
Either ignition on or engine running.
(light on basicly)
Either way will bring the light adjuster up.
(You can hear them.. like a short zzzzzzzz noise)
Then just adjust the allen key part to your levels you require.
