Water Droplets
mace¬
Car  Clio
I've had a play tonight with water droplets but they don't seem sharp. I think its the shutter speed but i've seen other peoples and they have used roughly the same as me. I got the 400D and the sync on the flash is 1/200th maximum so thats what I'm using, is this the problem or do you think I'm not in focus? been using Manual focus. All taken at F22-1/200th
My favourite
the centre image does look a little back focused.
In the top image is the drop on the way up....as there is a slight blur below?
Its possible its out of your depth of field???
Like fubar said try to pull back a touch thus letting us see more of the scene and also giving you more depth of field, which should help you get around the focus problem.
I see what your saying, I didn't want to get any of the bowl in the picture though so I had to go that close, I'm only using a Tamron 70-300 lens with a macro function aswell. I heard its not the best lens, just got all excited when I was in Jessops.
So even though I'm at F22 there is still going to be a shallow DOF due to my zoom?
could you not step back like said ^^ to get a better focus and then crop the bowl out using photoshop ?
Didn't think of that, as I just edited and added, I thought because I was at F22 I'd be ok with the DOF. Still alot of learning to do I think.
Depth of field is effected by F No/Focal length/ distance to subject.
so by you pulling back slightly you will increase your DOF.
Try to use a slightly bigger bowl
OK excellent, didn't realise it wa a combination of the 3, I thought F stop number was the only thing. I did have the camera as close as it would focus. Time to get a bigger kitchen, I think 30 foot should do it:)
ok next you will the need to factor in INVERSE SQUARE LAW....I.e flash output level.
If you double your distance from your subject you will need 4 x the amount of light???
confused yet??? lol
Confused!!!
Flashes were m next question.......
This macro lark is really getting to me so I'm going to get a macro lens. What am I going to need flash wise as with my little knowledge understand that the built in flash won't be good enough. What do I need and what does it cost??
If you don't already own a dedicated powerflash, then I would strongly advise one.
As for makes and prices ...its all down to budget.
You are looking for one that gives you full MANUAL/TTL control.
Metz/Canon will obviously be the best for you.
I think your droplets are suffering because of this.
Alo before you go feet first into MACRO ....this will have huge effects over DEPTH OF FIELD also.
MACRO"S are notorious for having very Small DOF.
Your first stop should be a Flashgun imho
I was thinking of something like the Canon speedlite 430x or whatever it is called.
Like you said I don't want to jump right in and waste a couple of hundred and find I need alot more.
Its amazing how much this photography can cost, I thought 400 notes would be enough!!!
Ring flashes are good for macro shots. Good shots btw mate, would like to get a macro and wide angle lense myself, but funds don not permit :D.
I've read about ring flashes but they are limited to Macro photos?? couldn't justify affording that, I'm on a budget like you mate and taking photos isn't cheap as I now know.
get a flashgun and an off camera cable.
A cable will give you the flexibility to use some different lighting techniques.
I use flash for almost everything I do ,apart from landscape stuff.
Its an excellent tool for daytime portraits.
