That exactly what i did too changed at 59k and 2 were fooked but 2 were fine?yeah 72k, but i changed mine at 60k and they were knackered then. personally they need to be change before 72k
cool cheers, are they the proper clio ones? Heard not to use anything else.
hi just seems abit lumpy on tic over like its got a small missfire but car runs fine and goes well seems like its ticking over too low but you carnt adjust tic over on these cars .gunna do plugs so then i now there okSorry to butt in and if my question sounds silly
But what do you mean by lumpy tickover ?
Can get 4xNGK PFR6E-10 off the 'bay for about 30 sheets, they're about £15 each from the stealers iirc.
http://cgi.ebay.co.uk/PFR6E-10-NGK-...ZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
Think that was the seller I had mine from.
Are these definately the correct plugs? I think I need to change mine as my is a bit lumpy @ 52k, plus for £30 it's not exactly an expensive job.
How can you tell if your sparks are knacketed?
