Parts Required for removing AC Pump
Car  Clio 172 Sport Ph2
Whilst the engine is out I think I'm going to remove the AC pump as I've no need for it being there - after all its just taking up space & zapping a couple of bhp whilst its at it! LOL!
Am I correct in thinking I'll just need a shorter belt & different tensioner to achieve this. Anyone got any Renault part numbers for these items please & an idea on cost?
Lee
Think you can switch to the cup aux setup, not sure if theres a belt that will just fit on the standard routing just sans the a/c compressor.
cup setup ain't cheap, you have to change to a cup alternator too
if you can get the bits off a smashed cup then it won't cost much, but to buy all the bits new you;re looking at about £400
plus you need to moddify the PAS line
Does anyone have the part numbers of the bits I would need please?
In what way does the PAS line need modifying?
Also are there any other cars in other ranges that use the same bottom end but dont have AC?
Cups do have their benefits ;)
Just a shame it didnt seem to benefit you much!!! LMAO! :rasp::rasp::rasp:
Does anyone have a diagram of the Cup setup please?? Possibly from Reno dialogys.
I take it the pulley used on the alternator is the same width etc.
