Large Exhaust Clamp?
Car  SchwepTek™
I have a blueflame cat back exhaust and silenced decat.
It is now blowing between the two and apparently its because the renault clamp isnt big enough.
I have been told that I need to find a bigger one, but dont know where, any ideas?!?!?
Its the clamps that are split horizontally in 2 with a screw either side holding them together.
anywhere, measure the size you need then phone a parts supplier
euros gsf mpd local places etc etc etc
theres only one type of clamp for the standard design of cat to center section.
I cant see how a bigger one is goin to help. You need to take the clamp off, re-line the 2 and clamp it tight. The blueflame is heavy right? probably causing the 2 to pull appart.
Unless the silenced decat is like this -
http://i3.photobucket.com/albums/y61/d4ve86/SlicencedDecat2.jpg
"Its the clamps that are split horizontally in 2 with a screw either side holding them together." - This sounds like the standard renault clamp to me.
If it has a rounded end like this - http://cgi.ebay.co.uk/ws/eBayISAPI....m=160236158217&ssPageName=STRK:MEWA:IT&ih=006
that fits to the flange on the center section, just do the 2 bolts up as tight as you can, or take it all off clean it and re fit with a new clamp from renault for £5
these are a b**ch - mine is doing the same and blowing which makes it sound pants. someone on here had the two parts welded together but i dont wanna do that. it looks like a really gash fit tho doesnt it.
It was me with the Horrible welded up Decat and Cat-Back... No Blowing from the Joint now :D
Just from the downpipe to Decat :( Got a new Gasket Kit for it but as with most renault Parts its really Ill fitting
Cheers all. I don't know what it is tbh. My mate works at Renault and he bought a new standard clamp and says it doesnt fit and I need a bigger one?!?! I dont think the blueflame is that heavy??? Its much lighter than the standard one. Maybe I should put the cat back on.
Dave - Its just a standard silenced decat with a belled end.
use exhaust gasket paste maybe :)
Don't bother. Use the proper stuff, the orange (or copper) silicon flange sealant - they sell it at Halfords, it costs about £4 and it's made by Loctite. It works, too! I had the same problem, it's now sorted.
