Mk1 Ph - :S
How do i tell the diffrence between a Mk1 Ph1 / 2 / 3 By just the bare shell ?
is any thing of the shell diffrent ???
Cheers - rob -
cat171
Yep as FM says.
- edit, dunno about the doors though, later cars may have come with side impact bars (I think they did tbh)
Has it got a sunroof cutout ?
cat171
What are you planning for it ??
The shell sounds to be a normal clio one (assuming that the rear arches aren't flared)
not really planning nothing, Just interested ( to see if i've started with a good base ).
As i've started a project on a 93 mk1 Ph1 Shell. and was just wondering what was diffrence in shells between the phrases.
cat171
Sounds like quite a project you've got on your hands, please kep us up to date with it.
I'd go for a valver,williams or a 172 engine in it. I'd also consider plating the sunroof over (unless you wanna keep it)
Looks like in the Ph1's shells there is a hell of a lot less tar / sound deadenin then the ph2/3s
I'm either going to Pop Vivit a Ally sheet in ( but don't no if this will look good or not )
or just get a new roof skin
