Clio 172 head gasket diameter
Car  RSTUNER'ED-C&B'ED RS-1
As can be seen from the title, I need the inner diameter of holes (bore) where the piston sits? Can anybody be kind of to measure it for me? I know the dia of the pistons but not a chance of getting the head gasket one's.
And also how thick is the original head gasket?
I know it is MLS so it should be around 1 mm.
Thanks
i've got one sitting here, but will only have a tape measure, so can't get precise readings..
:edit: ~84mm if that's any use
awesome, thanks mate.
Cometic makes two different head gaskets for F4R's. 83 and 84.5 mm. Which one should it be? Do you happen to have a caliber :)
