My photoshopped clio :) NOT a request :D
maybe leave it alone and save for another car , but if you want to have a play with the car then drop the rear loads :)
yer, not sure about suspension anymore :S and thanks to the guy saying my car is "s**t" maybe not your style but I like it
Mate lowering on a torsion bar is a piece of cake and safe as can be, took me half an out to do lower n be rolling again, no problem so far n it sits like this
DO IT lol!!!
if your thinking of keeping the car for a while i would lower it
i lowered my old mk1 60mm, looked great
oh and bargain car btw
forget the 5 door haters
lower it 60mm front an back.
your dad thinks lowering rear is unsafe because it rubs arches hard if you hit a big bump. thats because you should ideally buy aftermarket dampers to counter this problem. will firm up the rear to stop body roll and stop your tyres being destroyed on the arches if it happens.
if you get new alloys make sure you only go as wide as a 195tyre with alloys to suit. i found 205 tyre scrubs on 5 doors especially if you have 16 inch alloys and thats at standard height.
Don't lower it too much or it will look like your suspension's collapsed. Can't stand cars where you can't see the top of the tyre in the rear arches, looks absolutely f**king ludicrous.
About 2cm between arch and tyre front and back looks spot on - in my opinion of course.
nay my 106 was like that in the arch looks ok but aslong as its not in the arch by a daft amount your laughing you could see 3 or 4cm of my tyer with just me in it n then with a passenger about 2cm of the tyer lol
^^ my point exactly - one day you'll look back on it and see what I mean.
Lowered is fine, too lowered just looks silly ie: once any part of the tyre is covered by the arch.
lol you should of seen it when it was done 60 on the back, it was just going over the alloy by about 1cm didnt look good n i wasnt happy anyway didnt want it that low but the boffins at the garage thought i wanted it so the sills were level, divs
thanks for the advice man :)
s**t car.
s**t idea.
enough said?
w**ker
Enough said ?
Agree'd :approve:
Yer, I was thinking about 40 max? Maybe about 35
Thanks guys :)
