Is it ok to run your 172 on standard 95 unleaded
Car  Clio 172 sport
Is it ok to run your 172 on standard 95 unleaded?
With the fuel prices i am finding it more and more empting to buy the 95 stuff. I have seen this wynns unleaded upgrader - apparently upgrades normal unleaded to super?
Is this any good?
Is this any good?
I'm actually finding the prices getting more reasonable. Still stupidly high, but within a region where I don't cringe everytime I put some in.
My 182 has been pure Tesco 99RON fed for months now and I chucked another £30 in only today. At £1.14.9p, I don't think that is too bad, tbh.
In real world terms I don't think running on 95RON would harm the engine at all. I personally only use 99RON simply because it idles better and feels smoother on the uptake.
D.
Is this any good?
D.
same here it irons out the flatspots
Yea i suppose overall the cost of the more expensive stuff is only minimal, and they claim to give slightly more mpg.
Just out of interest has anybody used the wynns petrol upgrader?
Super is 3-4p per litre more expensive than normal unleaded, so even if you tank it you'd only save £1.50/£2.00 - is it worth it? Just stick the super in! The benifits of smoother idle and better pick up outweighs the extra cost easy IMO.
Read somewhere that 197's need to be ran on super... When I opened the fuel flap on mine sticker inside says 95 - 98 unleaded... I still use super though because..............its SUPER!!:)
Make your own! Acetone, Toluene or Methanol work a treat!
I used to run my 309 GTi on pure Toluene. Went like stink (stank a bit, too) with no problems. I wouldn't advise running a 172/182 on pure Toluene, as it'll cost a hell of a lot more to fix if it goes boom. That and the fact that the old Pug engines are strong as an ox.
That plus it'll melt all of your fuel lines :p
D.
Agreed
I use Tesco pumps as their super is 99ron. For the amount of money you save using 95ron, i think its worth paying that extra couple of quid for super.
But then that depends on how well you look after your motor?
You only get full power on 98ron.
For the sake of a few quid i don't see the problem... you could make that up by driving a bit more sensibly on your commute, checking your tyre pressures, not having the windows open etc.
99 ron fuel at tesco I do not find as good as vpower in terms of fuel consumption and perfromance. I dont think tesco is a true 99 ron, dont they just add something to it to boost it from 95-99. If i remember correctly the MON rating is rubbish
Sainsbury's superleaded for me in Megane.
V-Power in the bike.
The cheapest stuff I can find for the Mondeo, (normally Sainsbury's again).
Used normal leaded in both the 172 and Megane, did notice it in the 172.
just use the cheapest you can, it won't break anything
all the ferraris/lambos/astons/porsche's at work are run on normal cheap stuff and they're fine
I can understand peoples views on different fuels but realistically when you put it on paper if you fill up with normal unleaded at lets say £1.08 x 50L (11 gallons) litres makes it £54.00 or if you fill it with V-power at lets say £1.14 x 50L (11 gallons) makes it £57.00
£3 is hardly worth writing home about, a mere drop in the ocean for hot-hatch ownership imo
Pretty sure it's akin to the E5 we get here in Ireland. 95% petrol 5% ethanol blend giving a supposed 99ron rating.
the benfits like have been stated you will get running 98-99 is that the pick up, idle will be better as there is less preignition. using higer octane fuel it increases the resistance to burn i.e. will fire better and have less missfires and predetonation. Especially as the f4rs are a high reving engine the heat inside the cyclinders can easyly ignite the fuel at high revs.
ive seen in my car when using 95 the pick up has many flat spots, but when i used v power no signs at all. but im tight so 95 it is for me
Ive heard different mate, shell cannot guarantee 99ron every single batch and was tested, turned out to be true! Tesco 99ron was also tested and it showed the best consistency of 99ron throughout every batch - if that makes sense:)
Just what ive heard mind you ;)
Its totally fine to run the 172 on 95 octane.
There is no difference in gains of horse power or mpg.
run the car on what is is mapped to run on and no more!
The difference in octane fuels has nothing to do with the energy stored in the fuel.
The higher a fuels octane the lower the fuels volitility. making it harder to burn. this is suited for an engine where knock is applicable and pinking is regular. If your fuel is pre igniting / detonating then changing to a higher graded octane fuel can reduces or eliminate this. Ie. if you have advanced your timing or turbo charged an engine. obviously in this situation forced induction is cramming so much air and fuel in when the piston compresses the fuel ignites before the spark.
jap imports all have to run on the highest grade fuel.... because they are mapped for 100ron. this is standard fuel in japan. so when all the turbo cars come over here they will knock or pre det if the conditions are right and the fuel is wrong!
the clio doesnt have a forced induction and yes it revs, but not masivey high. mine does not pre det and it isnt mapped on 98 octane. even when im screaming it on the coldest possible day it runs fine and pulls like a train.
higher octane fuel burns slower than lower octane fuels do to prevent detonation. running more octane than you need will cause more engine deposits to form, and that will cause a decrease in engine performance and fuel economy.
High octane offers protection on engines that need it (turbos, nos, superchargers, highly modded engines with high compression) if your clio is seriously modded then run it. otherwise dont.
but what the f**k do i know, ive only owned my clio a week
most of the gains people get in the clio by putting v max or super in is all in the mind.:rasp:
Its just a shame wedon't get 99ron @Tesco up here :(
I sometimes run my 172 on 95ron and noticed no difference.
But from when i fir my RS Tuner Grp N Ecu I GUESS IT'LL BE 98-99 RON FROM THEN ON.
(Bloody caps lock) :(
Lets leave it with only a week shall we, if your driving 300miles in one go using 95 you will blow a spark plug straight out the top of your engine. Search for the posts or look at some of mine form about a year ago. We are using 98 in our clios to prevent preignition in our short stroke high revving engines not to gain performance!
p.s no hard feelings and welcome to clio sport.
