Anyone use locktite on the bolts to stop them loosening?
No need just torque them up properly with a torque wrench.
& as a tip smear some lithium grease around the thread before fitting, makes it a lot easier to undo, especially at the road side.
Halfords/ andrew page etc - as other guy suggested copper grease also does the trick, the idea is to stop the bolt from corroding because corrosion causes the bolt to expand which results in it seizing& as a tip smear some lithium grease around the thread before fitting, makes it a lot easier to undo, especially at the road side.
good tip thanks! were can this be purchased please motor factors?
^^ does that make a difference!![]()
90nm/66ft lb for the Clio and most other cars some are 110nm though.Had a bolt snap in the hub of a mates car a few weekends back. Nightmare.
I believe 70 - 75Nm is the correct torque.
