Brake Caliper Paint
  Clio 1.2 Dynamique
Looking for some decent orange brake caliper paint. Not sure where to look for it though, wonder what people can reccommend?
Thanks alot :)
cat171
I was going to say get some hammerite smooth - but I doubt they do it in orange.
Orange will look awful tbh.
Struggler
  Ph1 track 172
was some debate on here the other day about using brake calliper paint,
cnt vouch for that, bt i used hammerite, n never looked back
n im sure u can mix yellow and red,
will be hit or miss with the shade of orange tho lol
  ClioSport 172
I was thinking of doing mine orange but decided not to!
But anyway when I was looking you can get it from motorworld, cant remember the make but they do orange. And you can get it for about £15 on ebay
  Clio 1.2 Dynamique
this hammerite seems to be getting some good reviews.
seems u guys arnt all up for the orange though lol, what you think about yellow, then having the "1.2" on side written in yellow, and then maybe a decal or centre cap with yellow renault badge or sumfin? how does that sound??
or maybe the calipers in silver and the 1.2 stay silver aswell, with some nice decals, something like this http://www.eu-decals.com/index.php?act=viewProd&productId=332
  133, 182, Kangoo 182
I bought some Hammerite smooth earlier... Very few colours available, especially in the bigger tins.
  182
Upon seeing this thread and remembering I have a small tin of black hammerite (silk) I have just painted my calipers. Done in about an hour, from initial light bulb moment to everything put away again.
Looks much better!
Looks much better!
Pic time. ;)
They do red and yellow, bit of mixing and bobs your uncle
Was just reading my tin and saw something about mixing..
  182
Im supposed to be doing coursework and the car itself is filthy, so no pic time!
The paint says dont mix, but it also says ideal temp 8-25 deg so a bit more rule braking aint gonna hurt!
  RENAULT CLIO SPORT 182
just finished mine about 1/2 hour ago painted them in yellow hammerite smooth £9.99 for a 600ml can done 3 coats on all calipers and not even used a 1/4 of the can yet, done the drivers side 2 days ago really do look better once dried for a couple of days
  extreme 04
im also looking for orange paint,
hard to find tbh
theres some for focus st,
should do the job tbh, doesnt need to be a direct match as you cant see them that well...
but any other suggestions would be helpful as thats like £20
cat171
Blues not bad actually, although they look a bit odd having ebc greenstuff pads poking out the back (I guess you can't see it straight on though ?)
  Clio 1.2 Dynamique
yeah i was thinking that lol
think i might go with the silver,
thanks alot everyone for all the advice and comments, much appreciated
  182, SQ7, Trafic
The green actually looks quite smart as they are both really bright in person! Although the fronts have had green stuff for around 5000 miles and are caked in dust so soon it will dull off I'd imagine!
I also only think it works as the lip is blue on the wheels!
  Clio 1.2 Dynamique
i went with the black hammerite smooth
shud be on in next few days, and pics to follow shortly
GOING STEALTH
  Ph1 172 + Combo van
i had to paint some iron gates with hammerite but the gold colour was too bright so i mixed it up with a splash of silver and it worked fine! just make sure you make up enough first other wise it is hard to get the same colour again.
i redone my brakes today with hammerite. top marks as always!
  Shdhdhd
how many coats do you need? and with the paint do you need to prime or cover it in anything else after you have painted it like lacquer?
  Ph1 172 + Combo van
no priming needed really although you could if you wanted to.. just get atleast 3 coats on if you are doing them for the first time and make sure the surface is clean.
cat171
Give them a good clean up, then give them two or three coats of paint, it's worth leaving them to dry over night too, before putting the wheels back on & driving the car.
steve32c
  200T
Do a search on ebay for proper caliper paint and you will be able to get your orange
not a good shot as the sun went in but looks good when clean especially behind black alloys
  BG 182 FF
black or yellow imo, hammerite is good for the money but for my experience you will need to tidy it up every 18 months but is cheaper than caliper paint which is about 30 quid iirc
