exhaust knocking on rear beam
Jon.L
Car  911 GTS & Cayenne S
since its been lowered nto always but on the harsher bumps the rear part of the exhuast just before the back box knocks on the rear beam. anyone over come this?
i just made a topic about this a while ago
you've got to go to an exhaust shop and get it sorted, they usually change the bent over where it goes around the axel or they will shorten your center section that's what's happening with mine so it's getting sorted 1st november at an exhaust shop in aberdeen
It's the centre mount that is the issue as they're very weak.
Use a large jubilee clip shaped to fit around the central mount. Then it is simply a case of tightening the jubilee until the exhaust is sufficiently raised.
Having the same bother, just waiting for me new mounts to turn up and hopefully that will sort it
