Main beam not working on MK1 Clio
Car  Chav Rocket
Hi all
bit stuck, can get main beam when headlights are off but as soon as headlights are on then i cannot get main beam at all. have changed the stalk and checked all fuses.
any ideas please?
desperate!
Jonni
yes
stalk clicks over (sidelights) pull stalk - main beam
stalk clicks over (headlights) pull stalk - nada
any ideas?
shunt resistor? dash controller?
are you looking at the side-lights circuit?
I dont have the diagrams to look at but im 99% sure the main beam will not be powered straight through the stalk. Two main beam bulbs will be 2x65watt so 130w in total (or 10-11amps) which can only safely be switched through a relay.
s**t man. That is annoying. Must be a localised wiring issue? Fuse? or perhaps its another dodgy switch?
hi Tim,
on the Haynes its the diagram for exterior lighting..i can see the sidelight circuit and its different to the dipped/main beam one! if you know of a relay or are able to look at the diagram i would really appreciate it.
its well annoying mark!
also does anyone know where the reverse selector switch is? is it on the gearbox?
Thanks
Jonni
no, they dont go through a relay on the mk1
geesus seeing as u have done a fair bit or rewiring on ures can you tell me the main points to look for failure?
i'm stumped aswell lol
so you dont even get the momentary flash when on dipped beam? (not the constant main beam where it clicks)
have you ckecked all 4 of the fuses (think there is 4 lol) for the dipped and main beam? worth a look into
because of the way it is wired if the nearside bulb is shot then the offside doesnt work either as it breaks the circuit, but this still doesnt explain how they would work on sidelights but not on dipped :S
Gee, correct nothing at all when on dipped beam...! i have checked all fuses there are a few in the engine bay. only diff i can think of is that there is more load when headlights are on :( so confused!
hmm i'll have a think and have a look at my wiring and see what it could be
might be able to give you some things to check aswell :)
god we're talking about a mk1.
i had all sorts of issues with the stalks on my valver. Did loads of testing trying to work out where wiring issues were and it always came back to the stalks.
just because its clicking, doesnt mean its working!
We supplied a second replacment stalk, and i specifically tested it on the vehicle it was removed from for him. So stalk is definitely ruled out.
yes and i now have 4!lol
what component makes the main beam come on and stay on when on dipped beam? is it the stalk? if not im thinking that component is faulty
it is the stalk that makes it stay on
the only thing i can suggest is unplug the connector on the stalk, find which pin does main beam and bypass the stalk, if your lights flash its the stalk, nothing else it can be, if they dont work its something else lol
fixed! ok so i got 2 dodgy second hand stalks both people said that they were fine too appalling (sp)
i changed over the one that i had faith was definitely working as a final attempt before i pulled the tester out and guess what it worked!
oh thanks Joshydee the one you supplied worked a dream thanks for the other bit too.
now can anyone tell me where the reverse selector switch is? i need one!
thanks all
thanks all
Glad mine worked, made sure it was tested before sending it out, just shows like i was saying on the phone that stalks on mk1's are a nightmare.
first thing that came to my head when i read this was the stalk. I've had around 13 mk1 Clios in with the same problem always the stalk :)
cant be the stalk as i made sure it was working before it was removed for the car specifically as i know they are problematic.
Hello everyone! I'm very sorry for bumping this old thread but I just got here from Google while searching for the same problem...
So... my stalk does not click anymore when on dipped beam and as you can imagine there is no main beam. When the lights are off it does flash when I pull it towards me though...
Do I definitely need a new stalk or is it repairable?
Thank you.
Hi Pete, as said, it was a stalk problem.
Contact Josh at RenParts and he will sort you out with a stalk. (the original problem was stalk, but he bought two which were also faulty after, then Josh sorted him out with a working one).
