fog light,reverse light problem
Car  CLIO
hi guys, been a while i know...
anyway when i brake my fog light symbol lights up on the dash and also when reversing and indicating, when i reverse and brake my left indicator symbol lights up....could this be an earth issue as its just affecting the drivers side rear light
cheers james
Not sure where the earth point is for the rear lights but if you disconnect the wire block from the lights and give it a clean that may save you time trying to find the earth point. Most likely corrosion on the connectors mate.
I have the same issue when i brake, gonna take the lights out and clean the connectors..... let me know if this solves the problem if you do it anytime soon
il have alook at the weekend and let you know if it works
cheers james
I also have the same problem, when i brake the rear fog light on the dash comes on and when i indercate it flashes :(
hi all, seemed to have fixed the problem, take your rear light out, diconnect the plug and give it a good clean also clean your bulb connections and take the earth wire off and clean that... clean the screw that fasrtens up the rear light too as this seems to act as an earth also..... your main earth for the light is abit lower down than the cluster,just follow the dark grey wire that goes off from loom that fits into the light
cheers james
